Results 1 to 4 of 4
Thread: What kind of Copper to CPVC fitting is this?
    DIY Senior Member JerryR's Avatar
    Jul 2011
    Florida
    Default What kind of Copper to CPVC fitting is this?
    I have good amount of experience sweating copper. I also have done a lot of PVC work with my irrigation system. I have no experience with mating copper to CPVC. I've replace several water heaters using copper only. Our vacation home has CPVC connected to the heater which I will be replacing shortly.
    Looking at the pictures you can see the adaptor is sweated onto the copper not very far from the wall. I do not want to put a torch to this as it is too close to the interior garage wallboard. Not being familiar with this adaptor I have several questions?
    Can someone tell me how the CPVC attached to this fitting?
    Is it threaded?
    Can it be reused?
    Is the CPVC 90d a special 90 to connect to the adaptor?
    I will be replacing the WH and before cutting out the CPVC I want to make sure I have what I need to complete the job.
    Jerry
    JR
    Jan 2008
    It appears to be a copper to PVC transition union, which should unscrew.
    Jul 2011
    Florida
    So is it similar to one of these? I then should put an open end wrench on the flat to prevent the 3/4? copper from rotating and rotate the knurled ring counter clockwise with a pipe wrench?
    Jerry
    JR
    Jan 2008
    Using a pipe wrench could distort the knurled fitting.
    I would give it all I had with my hand first (a glove might help).
    If I had to use a tool, my first choice would be a strap wrench.
  1. What kind of union fitting is this? Ford Fitting
    By DavidTu in forum Plumbing Forum, Professional & DIY Advice, Tips & Tricks
    Last Post: 04-21-2011, 10:25 PM
  2. How to replace a copper fitting close to another fitting
    By jfhardy in forum Plumbing Forum, Professional & DIY Advice, Tips & Tricks
    Last Post: 11-26-2008, 08:48 AM
  3. Transition fitting from CPVC to PEX
    By bingo in forum Plumbing Forum, Professional & DIY Advice, Tips & Tricks
    Last Post: 08-18-2008, 05:49 AM
  4. What kind of PVC fitting is this?
    By stealth71 in forum Plumbing Forum, Professional & DIY Advice, Tips & Tricks
    Last Post: 08-01-2008, 05:32 PM
  5. chrome gooseneck to cpvc shower fitting - how do I ensure it doesn't leak behind the
    By Honest Bill in forum Shower & bathtub Forum & Blog
    Last Post: 11-01-2007, 04:31 PM
