Results 1 to 10 of 10
Thread: Any opinion on Goodman heat pumps?
    DIY Member gplumb's Avatar
    Feb 2007
    North Carolina
    Default Any opinion on Goodman heat pumps?
    A contractor has proposed Goodman 2 ton and 4 ton 16 SEER SSZ16 heat pumps for a friends house. I know the question of how good the Goodman units are has been asked before: they are low end units, the thickness of the sheet metal may not be as great as the better known brand unit, but the parts and manufacturing quality control are good. And something that is always mentioned - you must have a competent installer, but this is true of any brand.
    The SSZ16 has an long list of features, such as; scroll compressor, sound blanket, filter drier, suction line accumulator, compressor short-cycle protection, liquid-line filter drier, high capacity muffler, high and low pressure switches, service valves, copper tube coil, etc. See the SSZ16 complete spec sheet on Goodman's website (http://www.goodmanmfg.com/Portals/0/pdf/SS/SS-SSZ16.pdf).
    What is the current opinion on the Goodman 16 SEER SSZ16 heat pumps with scroll compressors? What is its overall reliability? Is this heat pump missing features of comparable better known brands for a 16 SEER rating?
    Mar 2011
    Houston, TX
    They are the best, Made in Texas. lol
    Springing for the extended compressor warranty may be a good thing.
    Don't let the price fool you. They do back their product.
    Dec 2009
    northfork, california
    Pretty much the same parts in all units made.
    Mar 2011
    Houston, TX
    True That.
    Service after the sale is the only difference anymore.
    But it is a Assembled in the USA product.
    Plumber jimbo's Avatar
    I assume that 16 SEER unit comes with a 10 year warranty?? All the more reason to have it installed by a top-notch contractor. He will be around to support the warranty, and even if not, Goodman will reconize that it was installed well and not hassle any subsequent repair contractor.
    Goodman uses mainly Copeland compressors. Doesn't get better than that;
    Feb 2007
    North Carolina
    Goodman SSZ16 heat pumps come with 10 year Parts and Lifetime Compressor Limited Warranties. If I go for the higher end DSZ16 which has a two stage Copeland compressor, two speed fan plus other features such as built-in diagnostic circuitry, the compressor warranty becomes a Unit Replacement warranty. I have not pursued the cost differential for that unit and think I am satisfied with the simpler SSZ16.
    DIY Junior Member mikeinkirkland's Avatar
    Feb 2012
    Kirkland, wa
    They're cheap. I've put a couple in rental houses. One has been great the other has had multiple problems. I generally agree with gplumb above but caution the warranties are often subject to the units being installed/maintained by an authorized dealer, being used with the correct indoor coil units, etc. In other words, you may find a warranty claim being denied unless everything was done 100% to spec.
    As for the "USA" part, that's hard to say. Many of the key components are farmed out to the lowest bidder--often China.
    I've had the best luck with Trane (or their other brands like American Standard) being all but bulletproof. But they tend to cost more apples-to-apples then Goodman. From what I've been told there are only 4 or 5 manufactures of most central HVAC equipment in the USA (each offering various brands). There are still some differences, but I think they matter less than some like to think. Look at SEER ratings, warranties, features, price, etc. before the brand name.
    Quote Originally Posted by mikeinkirkland View Post
    . From what I've been told there are only 4 or 5 manufactures of most central HVAC equipment in the USA (each offering various brands). .
    Goodman ( Goodman, Amana, etc)
    Ingersol Rand ( Trane group)
    International Comfort Products ( Heil, etc)
    Nordyne ( Gibson, Frigidaire, Comfort Range, etc)
    United Technologies ( Carrier, Bryant, Payne, Day&Night)
    Unitary Product Group ( York )
    Lennox ( not sure who the parent is)
    Rheem ( Rheem, RUUD, Weatherking, Duroguard, etc)
    Anyone know any others?
    DIY Member Geo422's Avatar
    Feb 2012
    Cin oh
    what the best brands
    DIY Junior Member MeloAir's Avatar
    May 2013
    Tampa, Florida
    Not really. Goodman makes their own coils. They use Copeland Compressors - Ohio, Genteq Motors - Indiana, Ranco Reversing Valves - technically London......that's pretty much your key components.
  1. 2 pumps in one well ??? Heat Pump and House
    By dancour in forum Pumps and Tanks Well Forum & Blog
    Last Post: 08-27-2010, 06:19 AM
  2. OT: Efficieny of Boilers vs Heat Pumps
    By chefwong in forum Boiler Forum
    Last Post: 05-01-2010, 03:10 PM
  3. Heat Pumps/Well Pump Problem
    By plantnerd in forum HVAC Heating & Cooling
    Last Post: 12-12-2009, 06:24 PM
  4. Heat Pumps After Thermostat Replacement
    By dickcarr in forum HVAC Heating & Cooling
    Last Post: 03-10-2009, 05:18 PM
  5. Goodman CPLE24-1C Heat Pump. Bad defrost circuit board?
    By sparker in forum HVAC Heating & Cooling
    Last Post: 02-26-2009, 10:13 AM
