Thread: Softner Drain freezing
    Default Softner Drain freezing
    What happens if the drain line freezes? Will it damage my softener when it tries to regenerate? or will it just not do it?
    Thanks!!
    DIY Senior Member mialynette2003's Avatar
    Nov 2010
    Ocala, Florida
    Other than possible cracking the pipe, nothing to the softener. If the water can not flow, then the softener can not regen.
    Dec 2009
    Alaska
    Drain line plugged or frozen.. will have the water go into the brine tank and depending on the float assembly it may or may not over flow the brine tank or salt tank depending on what one calls the tank that has the salt.
    Out side of that,,,,,,,, just what mialynette2003 said.
  1. Kenmore water softner: Water going in drain pipe continuously
    By gagan in forum Water Softener Forum, problems, installation and reviews
    Last Post: 01-21-2010, 12:34 PM
  2. Water Softner Drain to Black PVC 5" with Cap
    By weneedhelp in forum Plumbing Forum, Professional & DIY Advice, Tips & Tricks
    Last Post: 12-17-2007, 02:03 PM
  3. Drain in Driveway. How do I stop it from freezing in winter?
    By Zombateen in forum Plumbing Forum, Professional & DIY Advice, Tips & Tricks
    Last Post: 10-19-2007, 02:04 PM
  4. How to keep pipe from freezing? Drain or drip?
    By lithnights in forum Plumbing Forum, Professional & DIY Advice, Tips & Tricks
    Last Post: 03-25-2007, 06:33 AM
  5. PEX and Freezing
    By master plumber mark in forum Plumbing Forum, Professional & DIY Advice, Tips & Tricks
    Last Post: 12-16-2005, 02:19 PM
