Results 1 to 3 of 3
Thread: Wife wants the toilet moved
    DIY Junior Member dunkinidaho's Avatar
    Aug 2009
    Michigan, USA
    Default Wife wants the toilet moved
    :Wife wants the toilet moved "over there" so I'm doing it. Now installing the new 3in drain pipe through the floor. Do I cut this off flush with the floor? then glue on the flange? Unfortunately I've already glued the 3in into the old drain from under the house and ran it up a few inches higher than the floor in the new location. I'm hoping not to have to cut and splice the 3in from underneath. I should have bolted the flang down first I think, then hooked up the 3in last.
    Thanks again
    Brian in Florida
    Jun 2009
    Canada
    You want the flange itself to sit on the finished floor surface (tile, lino, etc.).
    You haven't buggered anything up by not gluing the flange on first.
    Depending on the flange you get (and I don't know if they make this in a 3"), you can get them with either a socket in the flange or a through hole. With a socket, the height of the pipe is critical because you want the pipe bottomed out in the socket when the flange is at exactly the proper height (well, there's often a little slop). On the other type, you leave the pipe long, glue things and when sliding the flange over the pipe, the pipe comes up through the middle. Once the glue sets and the flange is on the top of the finished floor, you then cut off the excess pipe sticking out the middle.
  1. Did my wife "break" our new toilet??
    By frank1890 in forum Toilet Forum discussions
    Last Post: 11-12-2008, 05:54 AM
  2. Angry Wife
    By afsteve in forum Pumps and Tanks Well Forum & Blog
    Last Post: 05-08-2008, 06:12 PM
  3. Filter moved
    By kd in forum Pumps and Tanks Well Forum & Blog
    Last Post: 01-31-2007, 07:19 AM
  4. wife says “fix the embarrassing toilet!” before the holidays.
    By thegov3 in forum Toilet Forum discussions
    Last Post: 12-19-2006, 01:38 PM
  5. Moved the trap, right?
    By andruesw in forum Plumbing Forum Discussion & Blog
    Last Post: 11-12-2006, 05:53 PM
