Results 1 to 2 of 2
Thread: Need help with a flange spacer.
    Default Need help with a flange spacer.
    The original plumbing was done in 1922. It's a cast iron flange set in a bed of mortar on top of pine flooring; 14" offset. I installed 3/4 plywood and then tile. Now the flange sits 1/4" below the surface in the front and 3/8" below the surface in the rear. A local plumber wanted $900 to tear it out and redo properly in PVC. I would like to use a spacer of some kind if possible? I know there are PVC spacers, but shouldn't I use some kind of gasket? Is there going to be an issue with the tilt of the flange? How much of a spacer do I need? Thanks in advance!!
    DIY Senior Member Mike Swearingen's Avatar
    Jan 2005
    On Albemarle Sound In Northeastern NC
    ario,
    You can use a flange extension made for the purpose and one wax ring, or double up two wax rings, one with a plastic horn on top down into the plain wax ring on the bottom. The wax ring(s) will fill the unlevel void and level out on their own between the flange and the toilet base.
    The toilet should be leveled with beveled plastic shims made for the purpose if necessary.
    However, THAT isn't your main problem. Installing tile directly onto wood (plywood or planks) will only result in cracked grout and tile due to the shrinking and swelling of the wood.
    The tile should have been installed on cement board screwed to the plywood.
    You're going to eventually have to rip all the tile out and do it right. When to do that is your call.
    Good luck!
    Mike
