Results 1 to 2 of 2
Thread: Convert Zoeller Pump with Piggy Float Switch
    DIY Junior Member ucik's Avatar
    Jan 2012
    Michigan
    Default Convert Zoeller Pump with Piggy Float Switch
    Any help is appreciated. I purchased a M98 Zoeller pump with float switch. This float is getting obstructed by the backup pump inside the sump and no extra space. I want to remove the float switch that came with the pump and install a SJE Rhombus or similar external tethered piggy float switch. How can I do that? Do I need additional seal kit?
    Thank you for your help,
    Ucik
    Jan 2008
    Actually, all you need to do is tether the lever for the switch in the up position so that it is on all the time. You can take the float off if you need the room.
  1. Buying a new sump pump - Zoeller with aftermarket switch?
    By Pickngrin in forum Pumps and Tanks Well Forum & Blog
    Last Post: 08-30-2011, 05:14 PM
  2. Best Float Switch
    By ArayT in forum Plumbing Forum, Professional & DIY Advice, Tips & Tricks
    Last Post: 07-04-2010, 11:13 AM
  3. What float switch for a waste ejector pump?
    By ric-a-pic in forum Pumps and Tanks Well Forum & Blog
    Last Post: 10-30-2009, 07:02 AM
  4. Zoeller Sewage Pump switch doesn't always work
    By cej22 in forum Plumbing Forum, Professional & DIY Advice, Tips & Tricks
    Last Post: 03-27-2009, 05:29 PM
  5. Sump Pump Float Switch Settings
    By ArthurS in forum Plumbing Forum, Professional & DIY Advice, Tips & Tricks
    Last Post: 10-06-2005, 07:40 PM
