Results 1 to 5 of 5
Thread: clogged vent stack
    DIY Junior Member Adam Myers's Avatar
    Jan 2012
    Annandal, MN
    Default clogged vent stack
    okay so I have that smells coming out of the toilet in the stack and I figured the vent pipe was clogged and it is. So I took the advice of some and tried the auger and that didn't work, I then use the garden hose with a high-pressure nozzle and turned the water on, the stack filled with water and has not gave yet, it's winter here so now I have two problems I still have a clogged event and it may be possibly frozen in the morning, what do I do?
    If the auger did not work, assuming you used the correct one, then it might have been ice clogging it in the first place.
    Jan 2008
    You can use a shop vac to suck the water out of the top of the stack. Tape the hoses together good so you don't lose them in the stack.
    Don't fall off the roof. Don't let the vacuum fall either.
    A short hose filled with water should siphon the water out.
    DIY Junior Member schustermarie54's Avatar
    Jan 2012
    Denmark
    Maybe someone dropped a huge bomb with a bird sitting on the edge of the pipe and passed out from the fumes. All joking aside though i would imagine one sniff of the top of the vent gives a pretty good idea if its working or not. I always try to find something else to do when it comes time to work around a vent.
  1. Main Vent Clogged
    By jeffopus in forum Plumbing Forum Discussion & Blog
    Last Post: 10-14-2009, 02:43 PM
  2. Vent stack
    By Creativeronos in forum Plumbing Forum Discussion & Blog
    Last Post: 01-26-2009, 09:09 AM
  3. Clogged vent stack or drain?
    By rawktron in forum Plumbing Forum Discussion & Blog
    Last Post: 08-29-2005, 04:49 PM
  4. clogged vent
    By mikeL in forum Toilet Forum discussions
    Last Post: 01-28-2005, 04:19 PM
  5. clogged vent?
    By bwatty in forum Plumbing Forum Discussion & Blog
    Last Post: 01-27-2005, 12:48 PM
