Results 1 to 8 of 8
Thread: 1980 house with black stuff around the bathtub drain. I'm putting in a new tub
    DIY infant SinnerDC2's Avatar
    Jan 2012
    Louisiana
    Default 1980 house with black stuff around the bathtub drain. I'm putting in a new tub
    I'm putting in a new tub and over course nothing fits. The problem is the drain centered, but its to low and the overflow is short and needs to move forward. I cleaned the area around the drain and it looks like black glass or epoxy, but from searching the forum I think it might be lead. The house was build in 1980 so it seems a little young for lead.
    Here are the drain pics. This if my first venture into non-faucet plumbing.
    link to bigger pictures
    https://picasaweb.google.com/tullost...eat=directlink
    It doesnt look very simple to replace the drain. Can I just raise the lower drain with some type of adapter? and raise overflow?
    Nick
    i wish my house loved me as much as I love it!
    Jan 2008
    Unless you are replacing a tub with an identical one, you should always plan to replace the drain and overflow assembly and sometimes the drain line will need to be moved. In an 80's house, I would not expect to find any lead joints.
    You are going to need to dig out the joint below that drain shoe and determine what the joint is. Unless it is in concrete, it shouldn't be too tough to make right.
    Jan 2012
    Louisiana
    I agree, the pics are super small. I enlarged them.
    Jan 2008
    Yes, I edited my post after seeing the linked pictures.
    Jan 2012
    Louisiana
    ok, i figured the black stuff was lead. I got if off another thead.
    what is the black stuff?
    Jan 2008
    Good question. Looks like someone had some extra roofing mastic they needed to get rid of. Someone's idea of waterproofing maybe?
    Jan 2012
    Louisiana
    after hours of searching online looking for something similar I found this post.
    http://www.diychatroom.com/f80/tackl...127745/index3/ , then I noticed our houses are the same age and the same location.. it must be a local plumber or something.
    IF your old drain and overflow had fit the new tub, THAT would have been a miracle. You almost ALWAYS have to relocate them, but HOW to do it varies with EVERY installation. Most users would NOT want to reuse the old drain fitting anyway, even if it did fit. That is NOT lead, but I am not sure what it is. It appears to be too "hard" and shiny for roofing cement.
  1. black sooty stuff - anode rod?
    By mavis in forum Water Heater Forum, Tanks
    Last Post: 03-24-2012, 12:55 PM
  2. Black stuff came out of tub spout for first minute or so.........
    By ih8caulk in forum Shower & bathtub Forum & Blog
    Last Post: 12-15-2009, 06:56 AM
  3. Black sticky stuff remover
    By edlentz in forum Remodel Forum & Blog
    Last Post: 07-24-2008, 07:03 AM
  4. black stuff coming from toilet
    By Susan123 in forum Toilet Forum discussions
    Last Post: 07-06-2006, 05:20 AM
  5. Black stuff and now...
    By Kent in forum Pumps and Tanks Well Forum & Blog
    Last Post: 03-29-2005, 11:36 AM
