Results 1 to 4 of 4
Thread: Crane (OEM) tub tap - H & C tabs - keep popping off!
    DIY Junior Member Shelley S's Avatar
    Jan 2012
    Ontario - Ottawa Valley
    Default Crane (OEM) tub tap - H & C tabs - keep popping off!
    I am replacing Crane acrylic taps on my sinks and tub taps (with same OEM version)... but the H and C "tabs" that "push on" keep popping off. Any suggestions?
    Feb 2011
    NW Ontario, Canada
    You may need to bend the little spring fingers out slightly. In a rental once I had that problem and cut short plugs of memory foam style earplugs to provide a little more pressure for the fingers.
    I suppose small balls of plumber's putty would work.
    Jan 2012
    Interesting idea, thanks... Did you put the foam "over" the small fingers? I did try bending the fingers out - all of them... maybe I should only bend a few of them?
    Feb 2011
    NW Ontario, Canada
    No, I put the foam plug inside the fingers so that as the memory foam expanded, it pushed the fingers outward.
  1. Sprinklers not popping up
    By Ginnyginny in forum Irrigation / Sprinkler Forum
    Last Post: 11-01-2009, 12:40 PM
  2. Tabs on plastic electrical box
    By toolguy504 in forum Electrical Forum discussion & Blog
    Last Post: 07-13-2009, 09:22 PM
  3. Popping noise
    By sctclimbs in forum Water Heater Forum, Tanks
    Last Post: 06-22-2009, 05:33 PM
  4. hootie rim tabs
    By pieper in forum Plumbing Forum Discussion & Blog
    Last Post: 12-31-2008, 12:49 PM
  5. Sprinklers not popping up
    By AZ1JoeT in forum Irrigation / Sprinkler Forum
    Last Post: 03-19-2007, 04:30 PM
