Results 1 to 4 of 4
Thread: Interior Drain Tile Installation
    DIY Junior Member johngandersonjr's Avatar
    Aug 2011
    Hilbert, Wi
    Default Interior Drain Tile Installation
    Hello,
    I have some existing interior draintile in my basement that is working very well.
    I also have a fruit cellar in my basement and the walls are holding water. Currently no interior drain tile there.
    The fruit cellar is cinder block like the rest of the house. it also has footings all around the room including under the door way to get into the room.
    Does anyone know how I would connect new interior drain tile from the fruit cellar to my other 3" perforated tile in the adjoining room?
    The door way into the fruit cellar has a footing underneath and I am not sure how to get through? Do I break out a 3" diameter hole to get the tile through, go underneath the footing?
    Any and all help is appreciated!
    John
    Aug 2011
    Hilbert, Wi
    Any one Have an idea?
    Jan 2008
    The tile should be set even with the bottom of the footing, so going underneath would not work (you can't make water flow uphill).
    A structural engineer would determine whether the footing can be penetrated safely depending on the load, the dimensions of the footing, and the soil type.
    It would probably be easier to put in another sump in the room that is not connected to the existing tile system.
    Dec 2009
    northfork, california
    A hole in the fruit cellar floor for a 130$ zoeller pump is cheaper than any lengthy cement tear out.. Dont need tile, the hole will fill nicely on its own.
  1. Please Help. Drain Installation for Tile Shower
    By emcconne in forum Shower & bathtub Forum & Blog
    Last Post: 02-13-2011, 01:18 PM
  2. I need to price an interior door installation.
    By mikeangelini in forum Remodel Forum & Blog
    Last Post: 07-09-2009, 05:53 PM
  3. Want to install interior perimiter drain in basement (waterproof). supplies???
    By thefed in forum Plumbing Forum Discussion & Blog
    Last Post: 01-17-2009, 12:17 PM
  4. Partial Interior Perimeter Drain?
    By ocbu9094 in forum Remodel Forum & Blog
    Last Post: 07-24-2008, 11:28 AM
  5. Interior French Drain
    By barumord in forum Pumps and Tanks Well Forum & Blog
    Last Post: 05-08-2007, 10:18 AM
