Results 1 to 5 of 5
Thread: picking submersable pump/ calculating resistance from a long run of water pipe
    DIY Junior Member kavik's Avatar
    Dec 2011
    tn
    Default picking submersable pump/ calculating resistance from a long run of water pipe
    I have a cistern fed by a spring and there is a submersable 4" 220 v pump in it. It is located a long way from my house. The water is pumped a little over a 1/4 mile through 1 1/4 " galvanized pipe. There is probably only 60 foot elevation rise. The pump needs to be replaced and I am wondering how to calculate the resistance of the water through the pipe in with sizing the pump. I have a barn halfway to the house with water. Currently, at 60 psi showing onthe pressure guage, water will flow at the barn, but not at the house. At 90 psi it flows well at the house also. I don't know what size/stage pump is in the cistern right now.
    As an aside, I was considering a constant pressure type pump, as the water volume at the house does vary cosiderably as the pressure tank drains/system cycles- anyone have any experience with them?
    thanks
    Nov 2010
    Maine
    You can find charts online or from pump companies that will give you the resistance
    Porky Cutter,MGWC Porky's Avatar
    Jan 2008
    Virginia Beach, VA
    My advise is to stay away from the variable flow pumps as they are a technological nightmare. Installing a Cycle Stop Valve in the line between the pump and tank is much less expesive, all mechanical (no additional electronics), it will extend the life of your pump, pressure switch and tank and it will give you constant pressure. I think that you can find out more about it by visiting http://www.cyclestopvalves.com
    Porky Cutter, MGWC
    (Master Ground Water Consultant)
    Feb 2011
    NW Ontario, Canada
    The math does not add up. You lose .43 PSI for every foot of elevation, so if there really is 60 feet of elevation from the barn to the house, there should be 26 PSI loss. 60 PSI at the barn then would be 34 PSI at the house and water should flow. How much flow of course, depends on resistance. I think you need a new pressure guage.
    As for variable speed pumps, such a long wire run would wreak havoc on the electronics.
    Dec 2009
    northfork, california
    http://www.freecalc.com/frdiresl.htm...etailCalc.y=39
    You can play with the numbers. But you should lose only 30 to 40 PSI at the end of the run unless your pipe is like most of our arteries after age 60.
  1. replacing check valve on submersable pump???
    By jaybob in forum Pumps and Tanks Well Forum & Blog
    Last Post: 05-08-2011, 12:29 PM
  2. replacing old pipe.....need help picking out what to use....CPVC, PEX, Copper???
    By firedogut in forum Plumbing Forum, Professional & DIY Advice, Tips & Tricks
    Last Post: 08-07-2010, 05:04 PM
  3. Calculating Propane Usage and BTUs for Tankless Hot Water System
    By Diavolicchio in forum Tankless Water Heater Forum
    Last Post: 12-21-2009, 02:04 PM
  4. 4 in. Submersable Water Pump Question!
    By BlakeJ in forum Pumps and Tanks Well Forum & Blog
    Last Post: 10-30-2009, 07:44 PM
  5. Submersable pump blues
    By nascar fan in forum Pumps and Tanks Well Forum & Blog
    Last Post: 03-18-2007, 12:01 PM
