So my house has very old galvanized water pipe. Had to turn off water a year ago and when It was turned back on I had no cold water in the bathroom. the sludge in the pipe was held back due to the water force. needless to say I had to replace some pipe. the size of the hole that of the feed pipe was ¼ or less due to build up. I used PEX and push on connectors to install a new water heater yesterday (relocation) . was so easy with pex. so I want to replace the old galvanized as far back as I can get hopefully to the water main. Would ¾ PEX be okay? I know it’s ID is smaller than copper and that what the charts go off of. Here is what I had in mind:
*note if I can’t get all the way to the water main can I cut the galvanized and use a compression fitting or something to go to PEX. *note would the threads of the galvanized pipe still be good after all this years?
