Results 1 to 4 of 4
Thread: Permanently Remove Cast Iron Baseboard Radiator
    DIY Junior Member rmoreira167's Avatar
    Dec 2011
    MA
    Default Permanently Remove Cast Iron Baseboard Radiator
    Hi there just a quick question as to removing a cast iron baseboard radiator. I have cast iron baseboard heaters throughout my home including in my living room where i have radiators on 3 of the 4 walls which seems excessive as the room gets quite warm. I want to remove the cast iron radiator from one of the walls and put in a vent free gas fireplace there, mostly for aesthetics as I said the room gets quite warm as is. It would also give me the opportunity to lower the heat throughout the rest of the house and use the fireplace when the majority of time is going to be spent in the living room. As I am trying to save a little money as I am obviously going to have to pay someone to come in and install gas to the area, my question is this, how do i remove the radiator. I assume I am basically going to shut the system off and bleed it and then cut the pipe going into the radiator and the return at the other end, remove the radiator, and then couple the two pipes i have just cut down in the basement so the system is complete again? Does that sound about right. Also how is the radiator fastened to the wall, i assume there have got to be screws fastening it to the wall. My radiators look like this one i found depicted elsewhere on the website.
    Also as far as the radiator goes, from looking around on the internet I see cast iron baseboard radiators are quite pricey, should I store the radiator in case something happens to other radiators in the house, it's an 8ft section? Or just junk it/give it away? Any help would be much appreciated. Thanks
    You do connect the two lines back together. It is held to the wall with a screw through the small square metal piece in the slot of the radiator. It is probably four 2' pieces rather than one 8' one, so save it for possible repairs someday.
    Dec 2011
    MA
    So i simply cap the return and the input pipes?
    Aug 2009
    South*East
    If it's a one pipe or two pipe system they can be caped. If it's a loop system (which I doubt) they must be tied back together.
    John
  1. replacing cast iron radiator supplys
    By williambonetto in forum Remodel Forum & Blog
    Last Post: 07-25-2010, 06:03 PM
  2. Picking the right cast iron radiator
    By johnfrwhipple in forum HVAC Heating & Cooling
    Last Post: 01-01-2010, 06:05 PM
  3. Cast Iron Baseboard Radiator
    By bjferri in forum Plumbing Forum, Professional & DIY Advice, Tips & Tricks
    Last Post: 11-01-2009, 04:57 PM
  4. bathroom cast iron radiator
    By chickenbrown in forum HVAC Heating & Cooling
    Last Post: 08-16-2009, 12:29 PM
  5. Cast Iron Radiator for New Room
    By 1890farmhouse in forum HVAC Heating & Cooling
    Last Post: 09-30-2007, 09:56 AM
