Results 1 to 3 of 3
Thread: Can I add a booster pump after a water softener?
    Default Can I add a booster pump after a water softener?
    I have a well system with an 80 gallon pressure tank. This feeds a standard resin bed water softener.
    The house water pressure is not great and can only be fixed by bypassing the water softener.
    Now, I am going to add a UV water treatment with a pre-filter. (due to coliforms in water now.....)
    I fear that my pressure and flow is going to be dismal after I do this.
    Can I add a booster pump after all of my filtering equipment? Would this act to increase the flow through the filters??
    My option is to add a storage tank and a pump but I would really like to do it with a pump. Any idea of pump size or how to figure out the flow numbers without cavitating?
    Thanks.
    Feb 2011
    NW Ontario, Canada
    I suspect a booster pump could draw a vacuum and collapse the down tube in the softener. If you have a pressure drop across the softener it either needs to be serviced or it is very undersized.
    Moderator valveman's Avatar
    Mar 2006
    Lubbock, Texas
    You might be able to just increase the pressure coming from the pump to the softner. Maybe as easy as just increasing the pressure switch setting. If you have to boost after the softner, you will need to draw from an atmospheric storage tank of clean water.
  1. Hot Water Booster Pump & Bypass Valve System
    By tacker in forum Plumbing Forum Discussion & Blog
    Last Post: 05-08-2011, 10:33 AM
  2. water pressure booster pump
    By steveleewonder in forum Plumbing Forum Discussion & Blog
    Last Post: 03-05-2009, 06:04 AM
  3. Water pressure booster and water softener
    By jneubig13 in forum Pumps and Tanks Well Forum & Blog
    Last Post: 03-22-2008, 08:23 AM
  4. New Booster Pump and Tank. Booster won't start??
    By TXTom in forum Pumps and Tanks Well Forum & Blog
    Last Post: 11-01-2007, 07:38 AM
  5. Water Pressure--Booster Pump?
    By dpmcclary in forum Plumbing Forum Discussion & Blog
    Last Post: 11-08-2006, 09:47 AM
