Results 1 to 2 of 2
Thread: motor sizing for radiant floor heat
    DIY Junior Member aztom's Avatar
    Jan 2012
    Arizona
    Default motor sizing for radiant floor heat
    I've got a loop of 475' of 1/2" (375 and about another hundred through three flat panel collectors,in parallel). There's about 14 elbows in the loop.
    How big of a motor and what type would get the glycol flowing fast enough to warm my concrete floor without being too big or heavy or expensive or noisy or power-consuming?
    I know my little Watts 500-800 1/25 hp. will hardly move the glycol at all.
    Should I be considering a 3 speed pump to help adjust the temp of the glycol.(i.e. not letting it boil, or be to cold to do any good)
    DIY Member Buffalobillpatrick's Avatar
    Sep 2011
    Stonewall Colorado
    So if we round off to 500' of 1/2" pex
    It would take 19' of head (8.1 psi) to move 1 gpm, and 65' of head (27.7 psi) to move 2 gpm. So there isn't much flow in your future.
    If you put 2x Taco 008 pumps (fairly high head vs. energy used) in series (output of 1st goes into 2nd) they would pull about 1.68 Amps & move about 1.2 gpm
  1. Radiant floor heat design help
    By Stilly in forum HVAC Heating & Cooling
    Last Post: 06-10-2008, 02:23 PM
  2. radiant floor heat??? Yes No Maybe So???
    By nocry in forum Remodel Forum & Blog
    Last Post: 02-19-2007, 01:26 PM
  3. Radiant heat pump sizing
    By Raucina in forum Pumps and Tanks Well Forum & Blog
    Last Post: 01-19-2007, 10:14 AM
  4. Radiant floor heat pex questions
    By Randyj in forum Boiler Forum
    Last Post: 12-17-2006, 11:23 AM
  5. In Floor Radiant Heat Leaks
    By chelle_89 in forum Plumbing Forum Discussion & Blog
    Last Post: 04-20-2006, 10:07 AM
