Results 1 to 6 of 6
Thread: Shower Mixing Valve or Tank not putting hot water through
    DIY Junior Member kwspears's Avatar
    Dec 2011
    Chesapeake, Virginia
    Default Shower Mixing Valve or Tank not putting hot water through
    I have a shower that can't get beyond luke warm. Sink next to it gets plenty of hot water. I have sterling fixtures throughout and the house is about 15 years old. I changed out the mixing valve, but that didn't completely solve the problem. I can finally get medium warm water if I let it run for 5 minutes, and then, every once in a while full hot water comes through (not good if you're in the shower!). Attaching 2 pictures. Do I need to replace the mixing tank/fixture behind the valve, clean something out somehow, or something else? Trying to avoid the major plumbing bill if I can....Name:  IMG_1382 (598x800).jpg
Size:  32.5 KBName:  IMG_1377 (598x800).jpg
    Do you have a hot water circulation system and pump? That valve does not appear to have a "temperature limiting stop", so if everything else is proper, you should get maximum hot water when it is turned all the way to the left. BUT, a malfunctioning circulation system CAN produce your symptoms.
    Plumber jimbo's Avatar
    The piece with the word "up" on it is the balancing spool. Pull it out with needle nose pliers, and replace it.
    Dec 2011
    I don't. Hot water works fine everywhere else.
    Dec 2011
    Thanks for the information on the balancing spool! Will give that a try. Is it there any trick to pulling it out? (Trying to avoid a Tim the Toolman moment!).
    Actually, it is the whole cartridge, and the "trick" is to have a new one on hand BEFORE you remove the old one.
  1. Putting tub spout on 4 port diverter valve with shower heads?
    By dujour in forum Shower & bathtub Forum & Blog
    Last Post: 01-02-2011, 03:10 PM
  2. putting hot water into a pot filler (single valve)
    By geniescience in forum Plumbing Forum, Professional & DIY Advice, Tips & Tricks
    Last Post: 11-30-2010, 10:40 AM
  3. Need new shower/tub mixing valve
    By Scuba_Dave in forum Shower & bathtub Forum & Blog
    Last Post: 10-26-2009, 11:17 AM
  4. Need to replace Shower mixing valve with separate cutoff valve for inputs.
    By OfficeLinebacker in forum Shower & bathtub Forum & Blog
    Last Post: 11-29-2006, 09:06 AM
  5. Pegasus mixing valve for shower.
    By canton in forum Shower & bathtub Forum & Blog
    Last Post: 02-20-2006, 04:22 PM
