Results 1 to 5 of 5
Thread: shower only rough in valve
    DIY Junior Member joeriley2005's Avatar
    Nov 2011
    Bothell, WA
    Default shower only rough in valve
    I'm in need of a shower only rough in valve for my remodel. Any thoughts on a good one? It doesn't have to be too fancy but I do want a good one. Something that a I can get replacement parts for if I need them. I also need it to be pressure balancing I believe for WA code.
    Thanks for your input,
    Joe
    Jun 2009
    Canada
    If you're worried about parts you should choose a brand that a local supply house stocks parts for.
    Get the Delta R10000 rough in valve. You then have a wide choice of trims, and you can choose basic one handle pressure balanced, two handle with separate volume lever, or thermostatic function. As with ALL brands and models, it is 4 port, and for tub only or shower only , you just plug one port.
    Feb 2011
    NW Ontario, Canada
    +1
    That is what I went with and plugged the unused port.
    The Delta body is the best option, but be sure to either insert the "bypass" plug inside it or install the cartridge. If using for shower only install the body upside down to eliminate future problems and give maximum flow. DO NOT, install the cartridge upside down, however.
  1. rough in tub/shower valve
    By GolfnRL in forum Shower & bathtub Forum & Blog
    Last Post: 01-13-2009, 07:10 AM
  2. Leak in KWC Shower Rough valve
    By garym in forum Shower & bathtub Forum & Blog
    Last Post: 11-04-2008, 12:29 PM
  3. Tub/Shower Rough In Valve
    By A Girl Can Do It in forum Plumbing Forum Discussion & Blog
    Last Post: 06-02-2007, 05:39 PM
  4. Shower valve rough-in, PEX...
    By mikepdaviskc in forum Shower & bathtub Forum & Blog
    Last Post: 02-14-2007, 09:48 AM
  5. Rough plumbing for tub/shower valve??
    By MYATT371 in forum Shower & bathtub Forum & Blog
    Last Post: 09-25-2005, 10:14 AM
