Fleck 5600 help
Akpsdvan
Alaska
The factory default is 2AM, that is as long as one has it on the current time of day.. ie if it is 7pm then 7pm should be showing in the little window at the bottom of the dial.
The 12 day pin wheel is just that.. if you need to have the unit clean every night, then every one of the pins should be out.
