General Ionics IQ0820B won't draw brine
Mialynette2003
Ocala, Florida
Got the resin installed, put everything back together, flushed out the whole system (took about 10 minutes at about 3-4 gpm), then did a regen for good measure. Unfortunately, the brine still will not draw so I am back to the manual process of closing the bypass valve and then slowly opening it back up to get the suction to start. Frustrating! Water is nice and soft, though, with the new resin.
Check the drain for any obstruction. If the drain line is partially stopped up it will cause the unit to fill the brine tank in a draw cycle. Once you put it on bypass, the pressure in the drain line is released and when you put it back in service, it will start to draw until the drain line fills back up. If it continues to draw, one of the seals is bad.
ditttohead
Water systems designer, R&D
Ontario California
This is a difficult fix because the first part of troubleshooting a valve that has 20 years on it is to start with rebuilding the head with new seals, spacers, piston, and drop in a new throat and nozzle, a couple seals etc. Unfortunately you have a proprietary valve that does not make this an easy fix. Most of the companies will not sell you there special parts because they want to send a "technician" out to try to sell you a new unit.
That being said, the problem you are having is not common, but has been known for many years. If it is not the seal and spacers, the injector assembly works on a venturi, for this to work, the nozzle water must not shoot perfectly through the throat. It needs to hit the sides and cause a water seal and thus create suction. This is why Fleck added the "Air Disperser" as they call it to the injector assembly years ago to most of their systems. It is a very rare occurance, and since your unit just started this, it is not likely the problem. The only reason I go there is because you say you get good suction when you cycle the bypass valve, this would disrupt the water flow through the injector likely making a good venturi affect. A very old trick (prior to the "air disperser" was to tweak the throat on the injector, or to make an imperfection on it that wold do the same thing as the air dispersor. In my 25 years, I have only had to do this maybe 10 times. I used to rebuild up to 6-8 softeners of every brand per day. In all reality, a 20 year old softener should be considered for retirment and it should be replaced with a non proprietary system so parts in the future are not an issue. Even the tank thread on your system is proprietary making a valve swap impossible. Many years ago we made an adapter to change the tank to a standard control valve thread, but that was too expensive and very prone to failures. It has since been discontinued.
Joe29365
Westerville, OH
Question about Filter Change on G.I. 0820B
In Aug. of last year ('11) moved into a house that has a General Ionics 0820B water softener which was installed in '84. There is some type of filter that needs to be changes and I have set up an appt. to have it change by a local G.I. Service company. Their service is $212!!!!:mad:They are the same company that serviced this unit for the previous owner. The unit was working but I had not put any salt in it. When I scheduled the service, they told me it would be best to bypass the unit until it was serviced so I did so. I noticed that the water in our house now tastes bad.
Does anyone know where this filter is that needs to be changed and how to change it? I unhooked the unit from the water supply. I think the filter that needs to be changed is inside the tank but I have no idea how to get the big valve off the top. Not sure if it unscrews off or needs to be pulled straight up and off? I'm guessing I have to get the filter from them but if I can do the work myself at least I should save some money.
