Page 1 of 2 12 LastLast
Results 1 to 15 of 24
Thread: General Ionics IQ0820B won't draw brine
    DIY Junior Member bmaker's Avatar
    Dec 2011
    Default General Ionics IQ0820B won't draw brine
    I have a 20 year-old GI unit that worked well until last month. During the regen cycle, when it gets to the brine draw step there is no vacuum on the brine draw tube. In fact, it actually leaks a little water out of the tube when I disconnect it from the float valve in the salt tank. However, if I move the bypass valve into Bypass position and then slowly return it to Service position, the vacuum is established and it draws fine. I have disassembled the brine valve and cleaned all the nozzles, jets, and screen (several times!). What gives?
    Dec 2009
    Alaska
    Sounds like the main piston along seal spacer kit might need to be replaced.
    When in the cleaning or regen cycle the main piston goes to a spot, if the seals are leaking then the brine draw will not take place even if the injector and screen are clear.
    It could be that by changing the middle seals with the seals that are at the ends correct the challenge for now .
    Dec 2011
    Where can I get a set of seals and, more importantly, the special tools (seal hook, puller, and stuffer) needed to remove and re-install them (which I will need even if I just swap them out as you suggest)? I found these in a Fleck 2500 service manual on line, and the whole shebang looks exactly the same. Thanks for the prompt reply above, by the way!
    Dec 2009
    Alaska
    I know that there are a number of items that yours and the 2500 have as the same, but if I remember correctly the seals spacers and piston are not the same.
    The stuffer and puller are nice to have, just used them on older 2500 yesterday, but will not break the bank if you do not have them, just takes a little longer with the valve off the tank and in ones lap.
    A few years back I ended up with some seal kits in a lot sale, trick is remembering where they are right now.. PM me if you would like.
    IIRC General Ionics used stock 2500 piston, seals,spacers and brine valve but, if not the stock parts still fit. You may have to ream (fine sand paper works) the brass to get any corrosion out before installing the new seals and spacers.
    Dec 2009
    Alaska
    Ok, then is this all wet?
    "NOTE: While the Valve may resemble the Fleck 2500 or 2510 ( front power head controls ), the "bore" size is LARGER, and that is why Fleck Pistons and / or Seals Kits will NOT fit.
    You will need to get those parts from a Puronics Dealer in your area ( or upgrade your complete Valve Head and TANK to "standard" sizes used with most other valves / brands )."
    http://www.softenerparts.com/kb_results.asp?ID=51
    Twenty +/- ago I rebuilt a lot of General Ionics 2500 based control valves.
    They didn't look like the picture on the link you referred to. They all had regular steel back plates, the type that rusted; just like to old Culligans... Then some started to show up with stainless steel back plates.
    If you look at the picture, take note of how large the tank it's on is. It must be 20" or larger. A 25x0 will not service that size tank. The back end of teh valve looks like 1.5" or 2".
    We'll see if the OP says he has that valve or not.
    Also, obviously softenrparts doesn't know about the tank adapter to adapt a regular industry standard 2.5' 8 third/inch valve to a tank with 2" fine thread. I used to carry one in the van at all times. Rainsoft's green tanks used the smaller hole too.
    Nov 2010
    Maine
    It's 20 years old, so spend the money and time to fix the leaking piston and a week later something else goes or the resin finally craps out. replace it
    Dec 2011
    Here are a few photos of my valve. Can you tell which one it is?
    Dec 2009
    Alaska
    There is an idea... if you could measure from side to side the part of the valve body that is flush with the metal back plate.. there are the two screws, one top and one bottom.. the Fleck 2500 body that I have my hands on has a left to right out side measurement of 45cm or 1 3/4.... now it is possible if yours is the same size then it might still use the 2510's piston and seal pack kit.. if not............. then it is looking for them from a dealer only.
    Dec 2011
    I measured as you suggested. Not exact due to the difficulties of getting my calipers in there, but I would say it's pretty close to 1 3/4". Perhaps a hair or two larger. This is at the flared out "flange" in contact with the back plate.
    Dec 2009
    Alaska
    This one just might be the 2500 body with some changes..
    I measured out side to out side of the 2500 body that I have and came up with the 1 3/4"
    It would be worth it to find a rebuild kit for the 2510 or 2500 and see if a local dealer will rent you the stuffer puller to work on your valve.
    did you get a photo from looking straight into the front of the control? you have from the brine piston side..
    It certainly isn't the same valve as pictured in the link.
    It uses the old standard brass by pass valve and meter although mounted 90* to the left instead of flat and the timer etc. looks the same. The injector body just behind the brine line connection, comes off the side instead of the top and is larger than a 25x0. I say the piston, seals and spacers probably are the same as for the present 2510 but... I was rebuilding day timer versions and not metered versions.
    If needed and you can get parts for yours, and you clean up any corrosion inside where the seals and spacers go, the valve body will last forever so I wouldn't get rid of this one simply because of its age.
    Dec 2011
    Didn't want to tear the front controller off to get this pic. Have done it before and I know the valve piston is a light green color. I'll see what I can find at a local dealer for the Fleck 25x0. Thanks!
    Dec 2009
    Alaska
    Let us know if there is any thing else that we can help with.
  1. Kenmore no brine draw
    By Cruisinfanatic in forum Water Softener Forum, problems, installation and reviews
    Last Post: 03-30-2012, 09:17 PM
  2. What Causes the Brine Draw to be Very Slow in Water Softener?
    By Biddle in forum Water Softener Forum, problems, installation and reviews
    Last Post: 04-06-2011, 09:26 PM
  3. General Ionics model 1240 not regenerating on it's own but can do it manually, help!
    By ras165 in forum Water Softener Forum, problems, installation and reviews
    Last Post: 08-13-2010, 10:09 AM
  4. General Ionics greensand filter parts
    By PEW in forum Water Softener Forum, problems, installation and reviews
    Last Post: 11-03-2009, 01:34 PM
  5. General Ionics salt softener problem..
    By mengel in forum Pumps and Tanks Well Forum & Blog
    Last Post: 12-19-2008, 12:04 PM
