Results 1 to 3 of 3
Thread: Takagi T4 starts with cold water use
    DIY Junior Member mlnk's Avatar
    Jul 2011
    Windsor, CA
    Default Takagi T4 starts with cold water use
    My new Takagi starts running and heating water when I turn off the cold water, like the garden hose. I installed a backflow preventer gravity valve then a spring type valve on the cold side feeding into the Takagi. Both did nothing. If I turn off the cold water slowly...there is no problem. The water pressure is 85 psi. How can I prevent it from coming on uselessly?
    Feb 2011
    NW Ontario, Canada
    I theorize there is an expansion tank somewhere absorbing the water hammer and the tankless is sensing the water movement.
    Jul 2011
    Windsor, CA
    There is no expansion tank unless there is one inside the Takagi. I was thinking of installing one to reduce the abruptness when the water is shut off. Also I was thinking I could reduce the pressure to 50 lbs with a pressure valve, or is 85 psi OK?
  1. Water Going Cold with Takagi Tankless
    By monty in forum Tankless Water Heater Forum
    Last Post: 05-28-2010, 11:09 AM
  2. Water starts/stops/starts
    By CaptPhoenix in forum Pumps and Tanks Well Forum & Blog
    Last Post: 02-27-2008, 07:42 PM
  3. No Pressure Water Starts and Stops Need Help
    By webbfamily2008 in forum Pumps and Tanks Well Forum & Blog
    Last Post: 12-07-2007, 07:13 AM
  4. Well Water Stops & Starts?
    By roozoo in forum Pumps and Tanks Well Forum & Blog
    Last Post: 08-22-2005, 07:50 AM
  5. Water heater pilot goes out when furnace starts
    By BillMorehead in forum Plumbing Forum, Professional & DIY Advice, Tips & Tricks
    Last Post: 02-15-2005, 04:22 PM
