Page 7 of 7 FirstFirst 1234567
Results 91 to 105 of 105
Thread: How much should the water level drop in a Kerdi Shower flood test?
  1. #91
    Jul 2009
    North Vancouver, BC
    Posts removed by John Whipple
  2. #92
    Jul 2009
    North Vancouver, BC
    Default Low Curb Shower Examples
  3. #93
    DIY Junior Member loudgonzo's Avatar
    Jan 2014
    Wylie, Tx
    Quote Originally Posted by johnfrwhipple View Post
    Who told you that bogus claim? Did you read it on the John Bridge tile forum? I certainly do not follow those rules and if you look at 1,000's of examples on Houzz.com you will see many others do not.
    I did not look up the pictures but will find some now for you.
    Can we agree that for now - the Kerdi Foam Curb looks like someone used a tool box as a shower curb and then tiled it.
    2" above top of shower drain, a standard code for US?
    leo
  4. #94
    Jul 2009
    North Vancouver, BC
  5. #95
    Jan 2014
    Wylie, Tx
    Leo please show us the exact code interpretation you are following. I would bet it is from an out dated source of info.
    For example if you search curbless shower codes you will find dozens and dozens of references to the John Bridge members talking about a 2" drop. This code is from the IRC and affects only a few states. The UBC and UPC are followed by many and these code books have been updated.
    Are you following more lame ass John Bridge Forum advice sighting the IRC or are you reading something from an updated UBC book?
    This is from our county website, page 3
    Section 417.5 Shower floors or receptors; amended to read as follows:
    Floor surfaces shall be constructed of impervious, noncorrosive, nonabsorbent and waterproof materials.
    Thresholds shall be a minimum of 2 inches (51 mm) and a maximum of 9 inches (229 mm), measured from top of the drain to top of threshold or dam. Thresholds shall be of sufficient width to accommodate a minimum twenty-two (22) inch (559 mm) door.
    Exception: Showers designed to comply with ICC/ANSI A117.1.
    http://www.wylietexas.gov/department..._IPC_2013.docx
  6. #96
    Jul 2009
    North Vancouver, BC
  7. #97
    Jan 2014
    Wylie, Tx
    sure, here you go:
    Wylie Municipal Complex, 300 Country Club Rd., Building 100, 2nd Floor
    Hours: Monday - Friday, 8:00 am - 5:00 pm CT
    Phone: 972.516.6420
  8. #98
    Jul 2009
    North Vancouver, BC
    Default Wylie Municipal Complex, 300 Country Club Rd., Building 100, 2nd Floor Texas
  9. #99
    Jan 2014
    Wylie, Tx
    Thanks John,
    I'm not so concerned with having a curbless shower as I am with getting a lower than 6" kerdi curb. So what I will do, is use the kerdi pre sloped pan and use bricks instead of the foam curb. I will look into getting a solid curb top instead of tiling the top of curb; and then try to set to the minimum height of 2".
    the pan is about 1 1/2" thick around the perimeter; so after tile and with the thickness of the solid curb top, I think the outside height of the curb could be closer to 4".
    Also, I think that by using a solid curb top, if it overhangs a little bit, it will make the curb as a whole look less "boxy" and more aesthetically appealing.
    Leo
  10. #100
    Jul 2009
    North Vancouver, BC
  11. #101
    DIY Senior Member Vegas_sparky's Avatar
    Dec 2013
    LV,NV/ Nowhere,UT
    That was a stand up move helping Leo like that, John. That's cool.
  12. #102
    Jul 2009
    North Vancouver, BC
  13. #103
    A shower curb should only be made from cement, bricks, block or of late for me Concrete Board. Wood should not be used. IF it is to be used it should be stable. Dry. Seasoned. KD. Export grade. If this is not available I would use paint grade plywood instead. Wood shrinks. Wood moves. Wood swells when wet. Concrete does not.
    Why it shouldn't be in wood -- the curb -- John ? Since you do residential work -- no metal studs involved -- all your blockings , studs , subfloor , etc. is in wood . What changes for the curb ?
    Other than -- no penetrations allowed -- through the curb , which is one of the most important advice found on -- John Bridge Forum -- the wood will survive if the building process is respected as per the walls . CBU's over it , membrane and the rest .....
    Even your steam showers are build over wood frame ...... don't know where you got the idea of no wood for the curb allowed is not a good one .
    Quote Originally Posted by loudgonzo
    Here is an example we did a while ago if you like the look of it . Costly but ...... worth the money .
    Name:  One slab piece --curb --.jpg
    And here is the diagram used for it , design by us.
    https://4bf306e5-a-62cb3a1a-s-sites....attredirects=0
    Roberto
  14. #104
    builder:anti-builder dhagin's Avatar
    Jan 2014
    oahu
    I'm with Roberto.
    Wood as a substructure for a curb, properly installed and water-proofed over a wood framed floor, is a fine installation. And has been for many decades throughout north America.
    Wood as a substructure for a curb, installed over a concrete or gypsum floor is not such a good idea. In these cases, a more dimensionally stable non-wood substructure should be used.
    dana
    __________________________________________________ ______________________
    in my youth, i knew it all and treated folks like they knew nothing. after 3+ decades in the construction business, i came to realize that the more i learn, the less i know. now i treat folks as i want to be treated - with respect, no matter how little i know. :-)
    Note: please don't feed or quote trolls. thank you. :-)
  15. #105
    Jul 2009
    North Vancouver, BC
  1. Can I Use Any Thin Set With Kerdi? The ICC-ES Evaluation Report On Kerdi Says You Can
    By johnfrwhipple in forum Shower & bathtub Forum & Blog
    Last Post: 01-08-2012, 10:19 AM
  2. Why does the vent have to be above the flood level rim?
    By tmpusr889 in forum Plumbing Forum, Professional & DIY Advice, Tips & Tricks
    Last Post: 03-22-2011, 07:42 AM
  3. Level a drop in tub
    By ajam in forum Shower & bathtub Forum & Blog
    Last Post: 02-07-2010, 06:01 AM
  4. Venting below flood level
    By pbr3232 in forum Plumbing Forum, Professional & DIY Advice, Tips & Tricks
    Last Post: 03-16-2009, 04:02 PM
  5. Air admittance valve - "above the flood level rim"?
    By schmeel in forum Plumbing Forum, Professional & DIY Advice, Tips & Tricks
    Last Post: 07-26-2007, 07:52 PM
