Thread: Pressure tank
    DIY Junior Member Beany's Avatar
    Dec 2011
    Green Valley Il.
    Default Pressure tank
    How often should my pump run : Well is 63 ft deep,submersible pump,pressure switch set at 45/65,44 gal. tank with 43 lbs of air. should pump kick on every 60 seconds, min and a half, how often
    Feb 2011
    NW Ontario, Canada
    How often the pump comes on depends on how much water you use. Measure how many gallons of drawdown you get to determine if the tank is waterlogged. I think you should see close to 10 gallons. Time how long it takes to refill the tank with no water being drawn.
    Consider installing a Cycle Stop Valve.
    Moderator valveman's Avatar
    Mar 2006
    If you are not using any water, the pump should never come on.
  1. Low pressure, pump stays on - tank, pressure switch? Replace all?
    By applebach in forum Pumps and Tanks Well Forum & Blog
    Last Post: 04-17-2011, 04:51 AM
  2. Pressure tank loses pressure after sitting for extended periord
    By Cudos in forum Pumps and Tanks Well Forum & Blog
    Last Post: 12-23-2010, 10:52 AM
  3. Convert propane tank to water pressure tank
    By jhv in forum Irrigation / Sprinkler Forum
    Last Post: 06-27-2008, 08:23 PM
  4. Replies: 1
    Last Post: 05-14-2008, 10:13 AM
  5. Bladder pressure tank vs standard pressure tank
    By brown13 in forum Pumps and Tanks Well Forum & Blog
    Last Post: 06-06-2006, 07:18 AM
