Results 1 to 2 of 2
Thread: Supply valve issue with Unifit
    DIY Junior Member texas1950's Avatar
    Dec 2011
    Texas
    Default Supply valve issue with Unifit
    Would like to replace current toilet with a Toto Vespin II; however the supply line is centered on the flange. Is installation of Vespin II possible in this situation?
    Feb 2005
    Omaha, NE
    Anything is possible - just costs more.
    Here's what Toto says about installation:
    Water supply must be approximately 8in. or 10in. to the left (facing bowl) from center line of closet flange and approximately 4-1⁄2" above the floor.
    So looks like the Vespin II uses the UniFit mounting system - which is a really slick system. I installed a Soiree a few years ago with this same system. I had to move my supply line 6 inches to the left. The best way is to open up the wall and put in new copper or other piping. I took an easier route and used a Sharkbite fitting (so I wouldn't have to solder inside the wall) and used a 6" piece of copper to move the supply to the left, but on the surface of the wall. It's hidden by the toilet unless you really crane your neck, and even then it looks pretty good!
    One nice thing about the UniFit system is that once it's in, you can lift the toilet (say, to paint or wallpaper behind it) without needing to clean up an old wax ring, and set a new one.
  1. Grohe faucet supply line installation issue
    By Phil L in forum Plumbing Forum Discussion & Blog
    Last Post: 11-16-2011, 07:30 AM
  2. GE Refrigerator Ice Maker Water Supply Issue - sprays water into ice cube bin
    By NiceMustang in forum Plumbing Forum Discussion & Blog
    Last Post: 02-04-2010, 07:57 AM
  3. Valve Placement for Toto Toilet with Unifit
    By organic_smallhome in forum Toilet Forum discussions
    Last Post: 08-13-2009, 03:17 PM
  4. Two Valve Temperature Issue
    By joebrueske in forum Shower & bathtub Forum & Blog
    Last Post: 06-28-2009, 07:15 AM
  5. Diverter valve issue
    By cwatts in forum Shower & bathtub Forum & Blog
    Last Post: 12-06-2007, 10:08 AM
