Results 1 to 10 of 10
Thread: What would cause a gas furnace to draw too many amps?
    DIY Junior Member kailor's Avatar
    Dec 2010
    Huntsville, Alabama
    Default What would cause a gas furnace to draw too many amps?
    Plumber jimbo's Avatar
    Exactly what do you mean by too many amps? As in it blew a fuse??? That is a short circuit, look for burned transformer, overheated motor, etc.
    Sep 2009
    Seattle. WA
    Stalled/jammed blower fan motor?
    Aug 2009
    Midwest
    Can the blower turn freely? I had a bearing failure in one many years ago, it seized. Interestingly, it didn't trip the breaker, and the blower motor didn't burn out...which was good because I couldn't find replacement bearings and had to rebuild it from parts I scavenged off another similar old blower that a shop had removed when replacing a unit. I think I handed the shop owner a couple of bucks for the old unit, other than that the repair was free.
    Anyway, I'm assuming blower because it is the biggest amp draw. The second biggest user would be the induced draft fan.
    quote; The second biggest user would be the induced draft fan.
    It may be the "second biggest draw", but it still a "Very small" one. We would have to know what he means by "excessive amps" and how he determined it.
    Dec 2010
    Huntsville, Alabama
    Merry Christmas everyone! I'm helping my sister-in-law with this issue. I'll try to find out what the amp draw was according to the repairman. No one available til Tuesday. She said they got the furnace running but did not know how long it would last. Right now, I've very limited information. Thanks for your inputs thus far.
    If the voltage was marginal (say in a brown-out), and things were 'on the edge' of accepability, it could draw excessive current and trip or blow a safety device. When I had my air handler/a-c unit installed, I installed a low-voltage cutout device. I think it was made by IDS. It's about the size of a deck of cards, has some controls on it to set the desired operating range, some LED indicators, and an internal relay to disable operation if the power is outside of parameters you set. No idea if it has saved my system, but it also has a time-out after power outages to prevent operation immediately after power reapplication when it can fluctuate radically for a few moments or so, thus further protecting things while the voltage is all wacky until it stabilizes. The internal motors probably would be okay, but the unit has at least a couple of circuit boards, and not asking them to operate until the power is stable is probably a good thing.
    Mar 2011
    Houston, TX
    Quote Originally Posted by kailor View Post
    Sounds to me that the service man, was blowing a little smoke. Maybe not.
    It is very disturbing how they take advantage of the unknowing. Maybe he spoke the truth. who am I to judge.
    If she called because of a blown fuse, then Jim's answer makes more sense than mine.
    Have a happy Holiday.
    Dec 2010
    Huntsville, Alabama
    The blower motor was bad.
    We appreciate that you came back and gave us the outcome. Sounds like the service man knew what was up but just didn't explain it very well. Motors do go bad, and hopefully this did not cost you too much...maybe an arm and just one leg, not both!!!
  1. Amps/kilowatts follow GPM?
    By chas2010 in forum Pumps and Tanks Well Forum & Blog
    Last Post: 08-25-2010, 10:09 AM
  2. Not enough amps for Toto Neorest/Now what?
    By Janjan in forum Electrical Forum discussion & Blog
    Last Post: 01-13-2010, 09:00 AM
  3. Not enough amps for Toto Neorest/Now what?
    By Janjan in forum Toilet Forum discussions
    Last Post: 01-04-2010, 11:01 AM
  4. How many amps can this panel handle?
    By yellowdog5 in forum Electrical Forum discussion & Blog
    Last Post: 05-22-2009, 09:48 AM
  5. 30 amps through #12 wire?
    By leejosepho in forum Electrical Forum discussion & Blog
    Last Post: 11-26-2008, 05:34 PM
