Results 1 to 7 of 7
Thread: Well runs constantly, pressure does not decrease
    DIY Junior Member Jjohns's Avatar
    Dec 2011
    Lutz, FL
    Default Well runs constantly, pressure does not decrease
    A little help, please! My well is running continuously. I shut it off at the breaker and the pressure (reading 70+) has not fallen after several hours. I drained the system and replaced the 40/60 switch. When I turned it back on, the pressure climbed back up to 70+.
    I drained the pressure back below 60 with the pump off and it's holding at that level.
    Any suggestions?
    Feb 2011
    NW Ontario, Canada
    The nipple to the switch may be plugged.
    The pump can ONLY pump to 70psi, but something will NOT shut it off before it reaches that pressure.
    Feb 2011
    NW Ontario, Canada
    The pressure switch may be wired incorrectly and is switching the neutral but the neutral may be finding an alternate return.
    Dec 2009
    northfork, california
    Buy a new pressure gauge and report back.
    Feb 2011
    NW Ontario, Canada
    ...or if it is a bladder tank, measure the air pressure on the bladder to very the water pressure gauge.
    DIY Junior Member Clydesdale's Avatar
    Dec 2011
    Manitoba
    Even though you put a new pressure switch; doesn't mean it's preadjuated properly. Did you adjust it? When you replace it, you should of seen water come out the nipple which would determine what LLigetfa suggested. Like ballvalve said, buy a new psi gauge and see.
  1. Pedistal Sump Pump constantly runs
    By loughrins in forum Pumps and Tanks Well Forum & Blog
    Last Post: 02-09-2010, 03:47 PM
  2. submersible pump runs constantly when running hose sprinkler
    By bobbiestoy in forum Pumps and Tanks Well Forum & Blog
    Last Post: 06-15-2009, 06:16 PM
  3. Well pressure problem and pump runs constantly
    By jmustang9150 in forum Pumps and Tanks Well Forum & Blog
    Last Post: 01-15-2008, 08:46 AM
  4. 2 residences one well; Pump RUNS constantly
    By James Taylor in forum Pumps and Tanks Well Forum & Blog
    Last Post: 10-21-2005, 06:34 PM
  5. No pressure, pump runs constantly
    By vic214 in forum Pumps and Tanks Well Forum & Blog
    Last Post: 10-13-2005, 06:13 AM
