Thread: Limited Space
    DIY Junior Member LV76's Avatar
    Dec 2011
    Delaware
    Default Limited Space
    I have a garage / workshop that has a small bathroom where I need to replace the existing 20year old toilet, but am limited in space between the front of the bowl and the wall. The existing toilet is a round bowl with dimensions from the flange bolts to the front of the bowl are 12.5" and the toilet is a 12" rough in but a 14" rough in can be installed, the max. I can fit is 14" from flange bolts to front of bowl. I would like a Toto because of the flush ratings seem to be the best, but not all spec sheets on the toto site note the measurements between the flange bolts and the front of the bowl. Any recomendations?
    The proper way to measure a rough-in is from the center of the flange to the wall behind the toilet. The standard is 12". to accommodate things a little better, some toilets are also made in 10 and 14" rough-ins. The rough-in has nothing to do with the length of the toilet, only the distance behind the flange to the wall.
    So, even if the spec sheet doesn't show the distance to the front from the mounting bolts, it's fairly easy. Take the overall length of the toilet, subtract the rough-in and add back in the space behind the toilet. If your rough-in isn't exactly 10, 12, or 14", then you'd have to adjust for that as well.
    Really, it just easier to measure your rough-in, and then compare the total length plus the designed in space behind to the wall.
    In the '"old days" a 14" toilet was the same dimension as a 12", but the opening was moved forward 2". Now, most companies use a 12" bowl and attach a tank which is 2" deeper, so a 14" toilet WILL project 2" further into the room than a 12", unless you can find a "true" 14" toilet which is 25" front to back.
    Toto makes the Unifit adapters for several of their toilet models that allow the same toilet to fit a 10", 12", or 14" rough-in just by using the appropriate adapter. The result is the toilet fits perfectly on any of the rough-ins. You can find these in the Shopping for Toto section linked from the "Toilet Review" at the top of this page. Toto is the only manufacture that makes such and adapter.
  1. Removing Cast Iron with limited access
    By youngin in forum Plumbing Forum Discussion & Blog
    Last Post: 01-08-2010, 09:33 PM
  2. Limited pressure in bathtub
    By frdm2004 in forum Shower & bathtub Forum & Blog
    Last Post: 12-28-2009, 05:47 PM
  3. New shower valve, limited hot water
    By Marc in forum Shower & bathtub Forum & Blog
    Last Post: 10-14-2009, 08:59 AM
  4. What water heater for a limited space
    By Dom Z in forum Water Heater Forum, Tanks
    Last Post: 08-06-2009, 09:08 AM
  5. Limited hot in the shower
    By eberwolf in forum Shower & bathtub Forum & Blog
    Last Post: 01-27-2009, 04:00 PM
