Results 1 to 5 of 5
Thread: inline filter
Hybrid View
    DIY Junior Member piecho's Avatar
    Dec 2011
    Western New York
    Question inline filter
    I have discolored water and want to put an inline filter before the pressure tank which the manfacturer frowns on. The physical layout doesn't allow me to install as they insist on installation instructions. My water recently is yellow brown color. I tested for common minerals including iron, all negative. The particulates are not organic and seemly not harmful. Casing 30', pump at 25' and water level 6' above pump.
    Jan 2008
    The existing piping can be re-routed to allow for a whole house filter, which should only be installed in the line downstream of the pressure tank.
    A cartridge filter will do little to remove discoloration, and often leads to more problems than it resolves.
    Dec 2009
    northfork, california
    I have three filters before my pressure tank without any issues. Except a cleaner tank. Add a pressure relief vale before the filters.
    Feb 2011
    NW Ontario, Canada
    Ja, but are they fine enough to remove discolouration?
    I have a single 100 mesh SS Banjo filter between the pump and the micronizer. It would do nothing to remove discolouration.
    Dec 2009
    this well seems to pump clay, perhaps some iron. I use 2 20's then takeit thru a 1 or a 5 and this gives pretty good water. Since its on a plain tank, the filters see NO pressure when the pump is off. I find it rather innovative. My snifter and drain valve are right there by the filters, not in the well which I find absurd.
    And with a 90 psi relief valve in front of the filters, when you see a shower in that area, you know the filters are plugged.
  1. need advice on inline filter...?
    By billfig in forum Pumps and Tanks Well Forum & Blog
    Last Post: 06-03-2011, 07:45 PM
  2. Use Chlorine (Charcoal) filter in Whole House Sediment Filter Housing ??
    By kstuart in forum Plumbing Forum, Professional & DIY Advice, Tips & Tricks
    Last Post: 03-03-2011, 02:04 PM
  3. Hooking RO filter inline
    By Fubar411 in forum Plumbing Forum, Professional & DIY Advice, Tips & Tricks
    Last Post: 02-16-2009, 12:20 PM
  4. Joining Pvc Pipes Inline
    By SUZY-Q in forum Plumbing Forum, Professional & DIY Advice, Tips & Tricks
    Last Post: 06-06-2006, 08:23 AM
  5. Inline TPR valve???
    By CharlieG in forum Plumbing Forum, Professional & DIY Advice, Tips & Tricks
    Last Post: 10-03-2004, 10:35 AM
