Results 1 to 2 of 2
Thread: Repair/Replacement Options
    DIY Junior Member SuperAcer99's Avatar
    Jun 2010
    Arizona
    Default Repair/Replacement Options
    Hello,
    I have a 16 year old 32k grain water softening unit with a Fleck 5600 Econominder Valve on it. The basket/screen on the end of the tube in the resin tank cylinder broke sending resin breads throughout the pipes in the house. I had a plumber come out earlier today to unclog the pipes and clear the faucets, toilets, shower heads etc as well as replace the ball on the Fleck 5600 valve because there was water leaking from it when it was in bypass mode. The timer on the Fleck 5600 was replaced recently so I think the whole Fleck unit itself is in good shape now, but the tube and resin in the cylinder tank need repair or replacement. I don't want to spend $1000 on a whole new complete assembly, especially since I don't know if I am going to stay in the house I am in for a long period of time. I would appreciate it if you all could give me some suggestions on some cost effective repair/replacement options?
    What ball on a 5600?
    Replace the distributor tube with a new one including the bottom basket and the resin. A ":32K" is a 1.0 cuft and has a 9" x 48" tank.You can get both online or from a local dealer or plumbing supply house. Shop the prices you get; expect somewhere around a max of $100 for the resin and $20 for the DT.
  1. Leaking water service in front yard. What are my repair options?
    By dayster in forum Plumbing Forum Discussion & Blog
    Last Post: 03-24-2011, 12:20 AM
  2. Handle Replacement options
    By jerome8283 in forum Shower & bathtub Forum & Blog
    Last Post: 09-26-2008, 10:50 AM
  3. Leaking valves...best options for replacement?
    By UKMyers in forum Irrigation / Sprinkler Forum
    Last Post: 05-12-2008, 12:07 PM
  4. Cracked Flange/Pipe Repair Options
    By Jeff_08 in forum Plumbing Forum Discussion & Blog
    Last Post: 03-26-2008, 08:30 PM
  5. Re-Pipe Material options PB replacement
    By sg789 in forum Plumbing Forum Discussion & Blog
    Last Post: 05-24-2006, 08:31 PM
