Page 2 of 2 FirstFirst 12
Results 16 to 20 of 20
Thread: Galvanized Tank Question
  1. #16
    Feb 2011
    NW Ontario, Canada
    I know what you mean about maintenance free. Now, if you neglect it, it will start short cycling and get gradually worse.
    Take note that there was some discussion of having two thirds air to emulate a bladder tank for more drawdown. Probably your AVC would not let you do that, but should your AVC fail or be too slow to vent, you could run into problems. If you have a filter or softener that backwashes, should the pressure drop (power fail or overdrawing the well) during backwash, the air could vent through the house plumbing and blow resin or filter media up through the system and clog things up. Ask me how I know!
  2. #17
    Dec 2009
    northfork, california
    Quote Originally Posted by BrianP View Post
    Got it. I do know how the AVC works. It worked everytime under the "old" system bleeding off the excess air put in by the air maker system each time the pump went on.
    I'm just pissed now that I went from a basically maintenace free tank situation to one where I periodically have to check and add air. All because I let the "well pro" talk me out of installing the valve to make air on the new piping installed in the well. He said if it becomes a problem for me, I can always switch to the captive air tank which he was trying to convince me to buy when he put in the new pump and piping.
    Put your air maker right next to the tank, you really only need a few feet of pipe to get enough air, then your vent likely will not ever need to vent. Most guys blow way too much air into a plain tank.
    Since the chinese are dumping air compressors on us for 39$ now, you could also put one on a timer for a minute a day.
  3. #18
    Feb 2011
    NW Ontario, Canada
    Ja, some folk use the bleeder to prime a trap in their basement. Like ballvalve said, most often there is too much pipe between bleeder and snifter.
  4. #19
    Moderator valveman's Avatar
    Mar 2006
    Whitewater even makes a compressor with probes for the tank to keep the right air level. Just make sure to use an oil free type compressor.
  5. #20
    In the Trades Texas Wellman's Avatar
    Feb 2010
    SE Texas-Coastal
    I like my galv. tanks. They allow a bit of sediment to settle to the bottom if you have any (I blow my tanks down once a year). They last forever if the water quality is even somewhat decent.
    The last two galv. tanks I replaced had '69 and '72 scrawled on the bottom. Tanks were still good.
  1. Galvanized Pressure Tank Question
    By muddyriver in forum Pumps and Tanks Well Forum & Blog
    Last Post: 10-16-2011, 10:50 AM
  2. Galvanized Tank Keeps Water Logging
    By Tenderpaw in forum Pumps and Tanks Well Forum & Blog
    Last Post: 03-03-2008, 04:53 AM
  3. Why Galvanized Tank and Bladder Tank?
    By dyoungers in forum Pumps and Tanks Well Forum & Blog
    Last Post: 05-09-2007, 08:17 AM
  4. Galvanized pressure tank 911
    By shyleeblue in forum Pumps and Tanks Well Forum & Blog
    Last Post: 09-05-2006, 04:01 PM
  5. Recharging a Galvanized Well Tank
    By Larry4025 in forum Pumps and Tanks Well Forum & Blog
    Last Post: 06-01-2006, 10:18 AM
