Results 1 to 5 of 5
Thread: NE DIY'er
    DIY Junior Member ewn's Avatar
    Dec 2011
    Papillion, NE
    Default NE DIY'er
    My GE Water Softener (GXSF39E01) is leaking between the bypass valve and the intake for the softener. There are black plastic clips, and I can remove the side nodes, but the top node on the inflow and outflow sides refuse to come free. I have turned off the water to the house, opened a faucet to drain pressure, and opened the bypass valve. How do I get those clips out without breaking them to check the seal, relube or replace, and reinstall?
    Dec 2009
    Alaska
    May have to move the bypass up or down a little, most likely that clip is in a bind and will come out once that bind is no longer there.
    DIY Senior Member mialynette2003's Avatar
    Nov 2010
    Ocala, Florida
    Pull the bypass toward the valve while trying to remove the clip. The leak is caused by the bypass itself. The ends are sonicly welded and tend the leak over time. I have done everything possible to stop the leak. Until you replace the bypass, the leak will continue.
    Feb 2005
    Omaha, NE
    Quote Originally Posted by ewn View Post
    To remove those clips, you have to release pressure in the softener itself. Easiest way to do it is put the bypass valve into bypass mode, then start a manual regeneration cycle. After a few seconds of the regeneration, the pressure inside the softener valve body will be low and you will find the clips will come off effortlessly.
    Feb 2005
    Omaha, NE
    So - were you successful at getting the clips off?
  1. Angie's List for the brand new DIY'er
    By Cookie in forum Computers and Stuff
    Last Post: 08-27-2009, 09:17 PM
  2. Re-soldering question from a DIY'er
    By Davebutch in forum Plumbing Forum, Professional & DIY Advice, Tips & Tricks
    Last Post: 06-03-2009, 01:52 PM
  3. old toliet.. new DIY'er
    By fletch in forum Toilet Forum discussions
    Last Post: 03-14-2009, 09:13 AM
  4. Too much for a DIY'er?
    By Gordon in forum Plumbing Forum, Professional & DIY Advice, Tips & Tricks
    Last Post: 12-25-2004, 09:28 PM
