Results 1 to 2 of 2
Thread: Thermostat location
    DIY Junior Member frozen's Avatar
    Dec 2011
    Michigan
    Default Thermostat location
    Just curious at to what the general consensus is for thermostat location. I've got an old boiler baseboard hot water system. Thermostat is currently in the living room/family room. The problem that I think I'm running in to is that with the lights and TV (42" flat screen) and everyone in the room, there is a lot of additional heat in the room. Would I be better off moving it away from these heat sources?
    I recently picked up a cen tech infrared thermometer from Harbor Freight and have been playing with it non-stop trying to figure out all my cold spots, etc. The bedrooms run about 5-8 degrees cooler than the living room. Turn the TV and lights off in the living room, and everything equals out. Just makes for a cold climb into bed at night.
    Jan 2009
    You've answered your own question. Putting the thermostat near a heat source, or having heat sources in some rooms, not others will always unbalance the system leading to hot & cold rooms.
    If you want a warm climb into bed, get an electric blanket (or a lazy dog. :-) ) Moving the thermostat to a different location will likely make the living/family rooms extra-warm when fully occupied.
    The alternative is to micro-zone the system, which can lead to short cycling and lower efficiency with old massive boilers unless you swap out the fin-tube baseboard for something with much higher water volume, or use a buffer tank as a hydraulic separator, plumbing it primary/secondary. (It becomes a real hydronic design problem.)
  1. Replies: 5
    Last Post: 09-19-2010, 08:48 PM
  2. Is it my thermostat?
    By cpio in forum HVAC Heating & Cooling
    Last Post: 11-06-2009, 05:09 PM
  3. Thermostat Help
    By Jafo in forum Electrical Forum discussion & Blog
    Last Post: 11-01-2009, 04:29 PM
  4. Can I use one thermostat?
    By fazy in forum HVAC Heating & Cooling
    Last Post: 11-09-2008, 07:27 PM
  5. what's behind the thermostat??
    By ginahoy in forum Plumbing Forum Discussion & Blog
    Last Post: 10-22-2007, 04:46 AM
