Results 1 to 12 of 12
Thread: Trouble removing excess silicone from sink
    Default Trouble removing excess silicone from sink
    Hi,
    I installed a new pop up assembly (Peerless) in this sink, and made a bit of a mess of it, I guess by not getting the excess silicone all cleaned off quickly enough. Still, I figured I would be able to get it removed, got to be a fairly common problem, I would think. But this stuff just doesn't seem to want to come off... that spot at the 7 o'clock position especially. I suppose the best route is to disassemble, scrub it, and redo, being a little more careful. But I'm concerned I still won't be able to get those marks off. I am wondering if there is something I could clean it with that would get it off? Lacking that, it is possible to find a slightly larger flange that I could replace the current one with to cover up any discoloring I can't get off? Thanks!
    Nov 2006
    Try something like a sharpened (chisel-ended) popsickle stick so you can scrape hard without damaging the surface of the sink.
    "Great minds discuss ideas, average minds discuss events and small minds discuss people." --Eleanor Roosevelt
    Feb 2011
    NW Ontario, Canada
    Plumbers putty is what should have been used there. Common methods of removal are mechanically scraping such as with a razor but there are chemical removals on the market.
    http://www.rpm-technology.com/Digesil/FAQs-Digesil.htm
    Try alcohol, but it may not work now that the silicone has set. That is one of the the reasons few plumbers use silicone.
    Thanks, all. You're right... I should have used putty, but I wasn't thinking. Instructions said silicone, I used silicone.
    Plumber jimbo's Avatar
    There are some well-known colleagues on the internet that use silicone exclusively. In my experience, the secret with silicone is cleanup before it sets. You need to treat it just like you do dap.....smoothing the bead if there is one, and totally wiping the excess. The caveat is that of course you can't do this with a wet finger or damp rag. You must use solvent. Two that work well are denatured alcohol ( not rubbing alcohol ) and mineral spirits.
    For your situation, you should be able to carefully scrape with something very sharp. That can be a carefully split popsicle stick, a new plastic putty knife, or even a sinlge edge razor blade. Held at a low angle, that will not damage the porcelain.
    LEARN SOMETHING EVERY DAY: Found this on a GE Silicone website:
    • Isopropyl Alcohol (IPA) is a commonly-used solvent and has proven useful for most non-porous substrates encountered in architectural construction applications. Xylene and Toluene have also been found useful on many substrates. When handling solvents, refer to manufacturer’s MSDS for inform
    Isopropyl is rubbing alcohol, and I had always used denatured methanol, because I thought it was 'better' !!! It is cheaper.
    I dissembled the popup to better get at the staining. Tried razor blade, Goof-Off, etc. but nothing worked. Then I tried a pumice "scour stick" and it worked great... took a little elbow grease but it's all nice and clean now. Going to use putty when I reassemble...
    Feb 2011
    NW Ontario, Canada
    I spent a lot of years in rental units where the landlord or handyman lathered way too much silicone everywhere, sometimes leaving handmark smudges all over that later harbored mold. I vowed never to use silicone except where necessary and to carefully mask off the area to not get it all over.
    Glad you got it cleaned off and hopefully you won't discover other smudges after mold sets in.
    Dec 2009
    northfork, california
    The only absolute solvent for not dry silicone is or was MEK methyl ethyl ketone, but may be banned now.
    I knew some MEK huffers....it fries your brain.
    Dec 2009
    I know a few PVC cement huffers that get pretty goofy in old age - mostly plumbers. Be careful.
    Consultant cwhyu2's Avatar
    Aug 2007
    Cincinnati OH
    We used to use zippo lighter fluid it contains napatha and worked great tooling and cleaning uncured silicone.
  1. Exactly how much does "all" mean when removing old silicone
    By watson524 in forum Shower & bathtub Forum & Blog
    Last Post: 02-07-2011, 05:16 PM
  2. trouble removing metal rimmed kitchen sink
    By Noahsoak in forum Plumbing Forum, Professional & DIY Advice, Tips & Tricks
    Last Post: 02-01-2010, 07:17 AM
  3. Removing silicone screw up.
    By Billy in forum Shower & bathtub Forum & Blog
    Last Post: 11-15-2008, 02:00 PM
  4. trouble removing old faucet - no room for basin wrench
    By grundy in forum Plumbing Forum, Professional & DIY Advice, Tips & Tricks
    Last Post: 07-28-2008, 06:09 AM
  5. Cast Iron Sink Excess Enamel
    By plumb confused in forum Plumbing Forum, Professional & DIY Advice, Tips & Tricks
    Last Post: 04-25-2008, 09:49 PM
