Results 1 to 3 of 3
Thread: Sleeving a sewer line in a condo
    DIY Junior Member Marita's Avatar
    Dec 2011
    Calgary, AB
    Default Sleeving a sewer line in a condo
    I need an expert opinion about installing a sleeve inside the sewer pipe. My condo is over 40 years old. Our board decided to use the sleeve rather than replace the pipeline. Considering the age of our sewer system, will the sleeve solution make our already narrow pipes "narrower" and will that result in more sewer back-ups? I appreciate your advise. Marita
    Yakima WA
    If the original pipe is 3", then any kind of sleeve will not be satisfactory. I really would be very skeptical of the whole sleeve idea in the first place. I think you are wise in seeking other opinions from the pros both on this forum and from other companies in the Calgary area. I can appreciate the desire to find a less expensive way to deal with the problem you apparently are having, but unfortunately cheap is usually not the best way to go.
    The success of a 'sleeve" depends entirely on what kind of pipe it is, and what the original problem is. "rough" pipe that cannot be reamed out will have a poor sleeve, and if the pipe has sags in it, the sleeve will just duplicate them.
  1. Sleeving PVC for concrete pour?
    By cacher_chick in forum Plumbing Forum, Professional & DIY Advice, Tips & Tricks
    Last Post: 04-01-2011, 06:39 AM
  2. Check valve on main line and toilet solution for condo flooding?
    By Flooded out in forum Plumbing Forum, Professional & DIY Advice, Tips & Tricks
    Last Post: 11-26-2010, 06:36 PM
  3. Sleeving Pipe to Garage
    By rmelo99 in forum Plumbing Forum, Professional & DIY Advice, Tips & Tricks
    Last Post: 09-29-2009, 08:59 AM
  4. Tapping new PVC sewer line into old existing clay line
    By Don Richmond in forum Plumbing Forum, Professional & DIY Advice, Tips & Tricks
    Last Post: 10-20-2008, 08:11 PM
  5. Sewer line to city line (sewer lateral) question r/o
    By H20Melon in forum Plumbing Forum, Professional & DIY Advice, Tips & Tricks
    Last Post: 02-11-2005, 05:12 AM
