Page 2 of 2 FirstFirst 12
Results 16 to 26 of 26
Thread: Low water pressure...pressure switch bad?
  1. #16
    Mar 2011
    Houston, TX
    Quote Originally Posted by jed1154 View Post
    What do you mean 'have enough wire'?
    I am taking off the old pressure switch, putting a T on the old nipple. Off teh side of that T I am putting a NEW pressure gauge and then putting the new pressure switch on top again. I should have enough wire for that.
    Thanks for the help! Ill try to do this tonight. I bet the nipple is dirty. My well pumps a fair bit of sand, requiring me to have a spindown/vuflow filter and clean it out monthly. It may have finally succumbed to that.
    Many times the switch is connected using Conduit, make the switch a bit harder to move.
    I normally just get rid of OLD , 10 years is a long time for most stuff to work. (Wife not included)
    Repairing Anything 10 years or older , is a temporary fix. But it can be done.
    To keep the pump from cycling as often you might want to check this site.
    http://www.cyclestopvalves.com/index2.html
    I Don't use enough water to justify the need.
    I know one thing, If Momma is not Happy, No one is happy. The Girls like their showers. Men do too.
    I bet she is ready for you to get it fixed. (You may need a good shower after the reward she gives You..)
    Good Luck on Your project.
    Don't pay someone to do a job fast, when you can do a half-fast job yourself.
  2. #17
    Mar 2011
    Houston, TX
    Ja, and a royal PITA for an abnormal person like me which was why I went with the EPS Cary shows in the picture.
    That is exactly why I made a block of wood, with a hole drilled in it for that shaft.
    If you can hold that lever until the pump comes up to 20 PSI, You have a dent in your finger.
  3. #18
    Feb 2011
    NW Ontario, Canada
    It's not the dent in my finger, it is the nagging in my ear when I try to explain to the wife over the phone how to hold that little lever.
    I just slip a nut driver over the lever like a mini cheater pipe.
  4. #19
    Mar 2011
    Houston, TX
    I did exactly the same thing until I made the wood block. For my Wife of coarse.
    If you use ¾ " square wood , You can drill the Hole so that you don't have to hold the lever.
    Then when it comes up to pressure the wood just stays on the lever.
    It defeats the reason for the lever, If you leave in on there, But makes it easier for the wife to restart it.
    Works good. I painted my wood and marked it "Water Pump"
  5. #20
    DIY Member jed1154's Avatar
    Feb 2008
    Texas
    OK guys...Im confused now:
    This is what I got:
    http://www.grainger.com/Grainger/SQU...e-Switch-2FH08
    My switch however that is on there is a '30/50' according to the label underneath. However, unless my pressure gauge is 10psi off, it most definately cuts off at 60psi and cuts on at 30-35....which used to be 40.
    I ASSUME the installer orders a ton of 30/50 and simply adjusts them out to avoid buying multiple kinds of switches.
    At any rate, will my new pressure switch work for my setup?
  6. #21
    Moderator valveman's Avatar
    Mar 2006
    To adjust a 30/50 switch to 40/60, simply turn the large adjustment screw three full turns clockwise.
  7. #22
    Feb 2008
    Texas
    I dont need to adjust it. I just got the 40/60 preset one. My question is, is the one I bought correct for my application?
  8. #23
  9. #24
    Dec 2009
    northfork, california
    Seems to me if everyone put in a 3/4 or 1" x 12 riser to the pressure switch, and reduces just at the end, no sediment would ever make it to the entrance port of the switch.
  10. #25
    Feb 2008
    Texas
    True, but even a taller 1/4" riser should accomplish the same thing, to a lesser extent. My unit pumps sand....if it was not doing that, it wouldn't be an issue though.
  11. #26
    Feb 2011
    NW Ontario, Canada
    In my case, it was minerals, not sediment and it didn't plug the entrance port, it built up under the diaphragm which limited the range of motion.
  1. Low water pressure after changing pressure switch.
    By cbr1grand in forum Plumbing Forum Discussion & Blog
    Last Post: 05-22-2011, 06:48 AM
  2. Low pressure, pump stays on - tank, pressure switch? Replace all?
    By applebach in forum Pumps and Tanks Well Forum & Blog
    Last Post: 04-17-2011, 04:51 AM
  3. Super High pressure, but pressure switch appears to work properly
    By yergnov in forum Pumps and Tanks Well Forum & Blog
    Last Post: 03-03-2009, 05:14 AM
  4. Replies: 1
    Last Post: 05-14-2008, 10:13 AM
  5. 2 Houses, 2 Pressure Tanks, 1 pump, 1 controller, 1 pressure switch pro help needed!
    By betaman in forum Pumps and Tanks Well Forum & Blog
    Last Post: 05-05-2008, 05:07 AM
