Page 1 of 3 123 LastLast
Results 1 to 15 of 39
Thread: Running wire for island receptacle in kitchen remodel
    DIY Senior Member TJanak's Avatar
    Sep 2009
    South TX
    Default Running wire for island receptacle in kitchen remodel
    From what I have read, I am required by the NEC to have a receptacle in a kitchen island. (I would like one anyways) Problem is this is a kitchen remodel and it never had an island. I would need to go from the bar to the island, ~40", to supply power. Slab construction.
    Is there any way with minimal concrete busting?
    I'm thinking drop cord from a reel at the ceiling The wife isn't too keen on that, though.
    What are my options?
    Travis
    When I need a precise measurement of something I often use the highly technical method of eyeballing it.
    Jun 2007
    North Carolina
    Take up the concrete and I agree with your wife but for different reasons.
    Sep 2009
    South TX
    Do I use conduit or direct burial kleenex, or something else? The rest of the wiring is nm kleenex.
    Travis
    DIY Senior Member Chad Schloss's Avatar
    Jun 2010
    USA
    (I love the new word for r o m e x (a southwire product) maybe we should use some of it to blow our noses
    Plumber jimbo's Avatar
    As far as I know, you don't have to "bust out" the concrete. I think you can groove it an lay in either UF or conduit. Speedey will straigten me out if I have this wrong!
    What if you knocked in two holes, a hole at each end and then looped under the slab?
    That way you could save the floor. 40" isn't very far to go.
    Jun 2007
    NY State, USA
    You'd need to get at least 2" of cover, so it is best to cut the slab about 4" wide down to the dirt and lay conduit.
    If you want to tile this area afterwards, you'll want to put in some rebar to help lock it into the existing slab. That can get tricky if the trench is narrow as it's tougher to drill dowels into the slab from a narrow trench. Not sure how you'd mine enough to get a wire under there from each end? Waterjet? Kind of tricky keeping it straight? Misread 40" as 40'...a waterjet could likely mine a tunnel under the slabe with just two holes.
    Make sure that the slab is not a post tensioned slab...that cannot be cut or you'll have problems, plus, it can be dangerous as well. Hit one of the high tension reinforcement cables, and it will ruin your day if not your life. These tend to be used in unstable soils or in areas prone to earthquakes.
    If there's any way to do a counter to ceiling feature, then your wiring gets much easier.
    Jan 2008
    When I plumbed my basement bath, I cut the trenches with a regular circular saw and diamond blades. Cut about 3/4" deep each pass until the cut was about 3" deep and then broke it out with a 10 lb hammer. Trickled water from a bike water bottle and followed with the shop vac to keep the dust down.
    I cut about 40 feet, and if I had to do it over, I would rent the right tool. BUT, in your case for 2- 40" cuts, a real concrete saw would be way too much hassle & mess.
    DIY Member kevink1955's Avatar
    Nov 2011
    L.I. New York
    The new word is also trademarked, wonder how long before Terry gets an E-Mail from them
    Jun 2007
    North Carolina
    sorry can't read
    Cut a groove in the concrete and lay the conduit in it. It will be cemented in so it does NOT need 2" of cover. It is NOT the same as installing a conduit BEFORE the concrete is poured. I hope when you say "A outlet", or "I would like to have ONE anyway", that you do NOT mean you will install a SINGLE outlet on the island.
    Sep 2009
    South TX
    I was thinking the same thing as Terry suggested. Just punch two holes and tunnel under the slab. I bet I could go 20" from each end by hand with some tools and maybe a 4-6" hole at each end.
    I also was thinking about the groove idea. Does it need 2" of cover or not? Does it even need conduit or could a person just use UF or whatever approved wire in a shallow (1"?) trench?
    Travis
    Quote Originally Posted by TJanak View Post
    I have seen that done. I can't tell you if code approves, although that job was definitely on a permit so presumably was signed off ,
    In the Trades mtcummins's Avatar
    Jun 2010
    Pittsburgh PA
    I would put it in conduit even if not required. It will be easy on that short run.
    I would not dig out underneath with regular tools... if you leave a pocket under there, the slab support will be compromised and you could get slab cracking, which will most likely transfer to your tile. If you're going to go that route, you need to remove only the amount of dirt needed to put in some conduit, which could be tricky w/o making very large holes on each end.
    Def put at least 2 outlets in, even if its a very small island. You need a minimum of one every 4 feet, one on any counter 2' wide, and w/in 2' of the ends. You can never have too many outlets in a kitchen, more is better.
  1. Kitchen Island rough-in
    By johnvb in forum Plumbing Forum, Professional & DIY Advice, Tips & Tricks
    Last Post: 12-30-2010, 03:20 PM
  2. Running wire between studs
    By hans_idle in forum Electrical Forum discussion & Blog
    Last Post: 01-04-2008, 03:54 PM
  3. Running wire through header
    By flyhop in forum Electrical Forum discussion & Blog
    Last Post: 11-29-2007, 07:17 PM
  4. Running a wire through a header
    By amartin725 in forum Electrical Forum discussion & Blog
    Last Post: 10-20-2007, 04:06 PM
  5. Kitchen Island Vent
    By william505 in forum Plumbing Forum, Professional & DIY Advice, Tips & Tricks
    Last Post: 09-03-2005, 06:39 PM
