Thread: need softener replacement advice
    DIY Junior Member temperamental's Avatar
    Jul 2011
    Port Richey, Florida, United States
    Default need softener replacement advice
    I live on the gulf coast of Florida where our water is not only hard, but has lots of chlorine in it...Currently have an Ultrasoft 280 that has served me well for about four years, but has now died.....Looking for a replacement that is reliable and not too expensive...Tired of these "store" brands that just don't hold up....Seems that it doesn't matter what you pay for them, they just don't last.....Had replaced the resin (was mush), and it goes through all of the cycles as it should, and still no soft water...The seals are probably worn.
    PLEASE, could use some advice on getting something decent, and some online retailers.....
    Also, is it possible to replace the control valve in this model with a better one, (tank and salt bin are like new), or isn't it cost efficient?
    Thatnks a lot for your time and help>
    Dec 2009
    Alaska
    You might look into two systems, one for the chlorine and then the softener.
    The one for the chlorine if you have the flow rate for it KDF 55 set to back wash every 3-4 days.
    There is away of changing a Sears like unit into one that keeps the media tank but can take a Fleck valve on top.
    DIY Senior Member mialynette2003's Avatar
    Nov 2010
    Ocala, Florida
    Depending on the amount of water used and the hardness will determine what system will best fit your needs. I prefer the Fleck 5600. It has stood the test of time. I sent you a private message.
  1. water softener advice please
    By BW in forum Water Softener Forum, problems, installation and reviews
    Last Post: 04-11-2011, 11:30 AM
  2. Need help/advice on water softener
    By senrab in forum Water Softener Forum, problems, installation and reviews
    Last Post: 01-13-2011, 09:53 AM
  3. Need advice on water softener
    By arbee in forum Plumbing Forum, Professional & DIY Advice, Tips & Tricks
    Last Post: 01-12-2011, 10:13 AM
  4. Need a new softener and I need your advice!
    By ElderBombadil in forum Water Softener Forum, problems, installation and reviews
    Last Post: 12-13-2010, 09:23 AM
  5. water softener advice please
    By BW in forum Plumbing Forum, Professional & DIY Advice, Tips & Tricks
    Last Post: 03-23-2009, 08:46 PM
