Results 1 to 5 of 5
Thread: Vent requirement for basement floor drain (Canada)
    DIY Member grahamW's Avatar
    Jan 2012
    Ontario, Canada
    Default Vent requirement for basement floor drain (Canada)
    I'm contemplating my options for locating a 2" vent in my basement which will serve my relocated laundry and floor drain. I was talking with a fellow at the local (independent) plumbing store and he advised that, in Canada, a floor drain does not need to be vented if it is minimun 3" in size, and the trap arm (pipe from the main drain to the trap) is a minimum of 16" long, maximum 12 feet with 1/4" per foot grade on it. Can anyone here confirm this? For what it is worth, my current basement floor drain isn't vented.
    you don't need to vent the floor drain provided:
    it is not less than 3"
    length of fixture drain (trap arm) is not less than 18"
    the fall does not exceed the size of pipe (3" fall for 3" pipe)
    it is connected to horizontal drain that terminates at its upstream end in a 3" stack
    DIY Junior Member jpb123's Avatar
    Jan 2012
    Iowa
    Quote Originally Posted by mikeplummer View Post
    Can the trap arm be less than 18" if it is within a certain distance of a stack or vent?
    Jan 2008
    The guy from Iowa should not take advice from the guy from Canada, as the plumbing code is not the same.
    very true...
    to answer the question ...no ... trap arm cančt be less than 18"...period
  1. Vent a Basement Floor Drain with an AAV?
    By i'm my own troublemaker in forum Plumbing Forum, Professional & DIY Advice, Tips & Tricks
    Last Post: 04-11-2011, 12:09 PM
  2. floor drain, Canada
    By christoff in forum Canadian Plumbing Code Questions
    Last Post: 06-20-2010, 04:48 AM
  3. floor drain, Canada
    By christoff in forum Plumbing Forum, Professional & DIY Advice, Tips & Tricks
  4. trap primer for the floor drain, Canada
    By simmy1919 in forum Canadian Plumbing Code Questions
    Last Post: 06-02-2010, 07:31 PM
  5. Basement floor drain - vent required?
    By mao in forum Plumbing Forum, Professional & DIY Advice, Tips & Tricks
    Last Post: 12-26-2006, 05:47 AM
