Page 10 of 13 FirstFirst 12345678910111213 LastLast
Results 136 to 150 of 183
Thread: CFL Bulbs that really last for 5 Years
  1. #136
    Homeowner
    Jan 2010
    Alabama
    I talked to a rep at Intermatic recently about photo controls. There is a difference between brands, as has been discussed here. Less expensive photocontrols are not true "off". They are electronic swicthes, which have some leakage, and that is what drives fluorescents and LED's crazy. Most of Intermatics models contain an actual physical off/on switch and are fully tested to support fluorescent lamps of all types.
    What is a rep? Are you abbreviating representative without the period?
    What are "swicthes"? Some new type of switch?
    Why did you use an apostrophe like this.......LED's. Is that correct grammer?
    The rules for apostrophes vary with the type of word. Learn where to put apostrophes so that your writing is clear and correct. In short, apostrophes are frequently used to indicate possession and in contractions, but never to pluralize.
  2. #137
    Dec 2009
    northfork, california
    Heres a LED bulb for $8.99.... try one and report back
    http://www.1000bulbs.com/?utm_source...Bing_PPC_Brand
  3. #138
    Dec 2009
    This Program has a doubler glitch.
    Also, here is the ONLY timer left on the market at a good price thats NOT digital crap. Made in germany: http://www.1000bulbs.com/product/3380/ELEC-GM40.html
  4. #139
    Mar 2011
    Long Island, NY
    I still have and use at least one old Intermatic timer that is all mechanical, plus the clock motor and the micro switches actuated by those metal pices that clamp to the wheel. Had them before 1987, but that's when I put them into use. Still work, and they are outdoors only in their own raintite enclosures.
  5. #140
    DIY Junior Member
    Feb 2012
    India
    CFLs are four times more efficient and last up to 10 times longer than incandescents. A 22 watt CFL has about the same light output as a 100 watt incandescent. CFLs use 50 - 80% less energy than incandescents.
  6. #141
    Mar 2011
    Houston, TX
    Quote Originally Posted by Ericaminto View Post
    You have had better luck than I, If your life figures are real time.
    Or are you going by what the package says ?
    Maybe the key words are "up to" 10 times longer.
  7. #142
    Mar 2011
    Long Island, NY
    Yah, I think she's reading that info from the box and not talking from 'sperience.
  8. #143
    Plumber jimbo's Avatar
    Quote Originally Posted by Hackney plumbing View Post
    My bad on the apostrophe. I know better than that but I was careless. Rep for "representative", is a noun, not necessarily in the OED, but widely accepted in trade circles without the period. The switch, if I understood him correctly, is a bimetallic, something like what might be found inside a thermostat. It is a physical switch which is either conducting..or INFINITE ohms. Electronic switches do not "snap" open to closed in the same manner, and very typically have leakage current even when the light should be "off". Devices with electronic drivers, like CFL and LED , do not respond well to such leakage currents.
  9. #144
    LIFE CYCLE. The industry standard measure of the life-hours for a product is to put 10,000 items in a room. Subject them to whatever is considered the "normal" off/on cycles, possibly accelerating the cycles. At the point where exactly HALF the bulbs have stopped working, THAT is the listed hour lifetime for that model.
    A rep from American Fluorescent recently explained to me that it is a little different with LEDs. The element may run 30 years + and still be putting out light. But the elements do get dimmer as time goes by. Up to the stated life...let's say an item is an 8 year rated LED....the brightness is nearly the same as brand new. But then as further time goes by, it will get dimmer and after a certain period of time will be considered unsatisfactory, and that is when you replace it.
    Yes, I do get to meet a lot of "reps" .. Long story.
  10. #145
    Mar 2011
    Houston, TX
    I still have incandescent bulbs that have lasted much longer than these GE CFLs in the same room.
    When a incandescent gos bad it gets brighter, for a split second. I have even heard them sing.
  11. #146
    Mar 2011
    Long Island, NY
    Must be the fat lady inside. It ain't over till the fat lady sings. COULD NOT RESIST THAT DON! Thanks!
  12. #147
    Mar 2011
    Houston, TX
    Default Lost another CFL at around 1500 hours
    Quote Originally Posted by BobL43 View Post
    That is funny Bob.
    I turned it off after I heard her singing, and she stopped singing, then I turned it back on and she Blew. I guess she got pissed off.
    I just lost another GE 6500K CFL this morning, I estimate it had about 1500 hours of use. less than 1 year old.
  13. #148
    The major manufacturers warrant their CFL bulbs for the stated life...typically 6000 to 8000 hours. You should be able to return those to place of purchase.
  14. #149
    And apparently this thread will last 5 years, even if the bulbs don't!
  15. #150
    Mar 2011
    Houston, TX
    They are in warranty, but the shipping to China would cost more than a new bulb. Or would they just send new ones, Same Junk ?
    I want to take them apart and see what failed.
  1. Cold cathode CF bulbs?
    By Bill Arden in forum Electrical Forum discussion & Blog
    Last Post: 01-27-2009, 11:48 AM
  2. Bulbs are humming
    By vegashomes in forum Electrical Forum discussion & Blog
    Last Post: 10-20-2008, 08:40 PM
  3. Compact flourescent bulbs
    By cathead in forum Electrical Forum discussion & Blog
    Last Post: 03-16-2008, 09:01 AM
  4. Two F4T5/CW bulbs failed
    Last Post: 02-06-2008, 08:46 AM
  5. photoelectric eyes and CFL bulbs
    By plinkadinkadonka in forum Electrical Forum discussion & Blog
    Last Post: 09-21-2007, 09:27 AM
