Results 1 to 2 of 2
Thread: Setting pressure in hot water boiler
    DIY Junior Member tombstone's Avatar
    Feb 2008
    New York
    Default Setting pressure in hot water boiler
    Good Morning ...
    On Saturday I finally got around to installing a Runtal basebord radiator as a replacment for a cast iron radiator that was removed for a bathroom remodel a few years ago. I bled everything several times throughout the weekend and am getting good heat from the system but the pressure was at 30 psi this morning when I checked it.
    I have an older expansion tank and am planning on isolating it and draining it today after work. The boiler is in the basement and I have a two story cape cod.
    Is there anything else I should be looking at? A HVAC guy said the autofill seems to be working. Are there any adjustments that can be made in the autofill?
    What should the standing pressure be and what is an acceptable pressure when the boiler is running?
    Thanks for any and all advice.
    Feb 2008
    New York
    I posted this in the wrong forum and have reposted it in the boiler forum.
    Sorry.
  1. Boiler water pressure too high ...
    By jgraves in forum HVAC Heating & Cooling
    Last Post: 02-15-2011, 12:32 PM
  2. Setting water pressure question
    By djryval in forum Plumbing Forum, Professional & DIY Advice, Tips & Tricks
    Last Post: 02-01-2010, 09:44 AM
  3. aquastat setting and boiler question
    By bbillcee in forum Boiler Forum
    Last Post: 10-12-2009, 05:37 PM
  4. Temperature setting on new mod-con boiler/water heater
    By Montalvo in forum Plumbing Forum, Professional & DIY Advice, Tips & Tricks
    Last Post: 12-12-2007, 08:22 AM
  5. Water Hammer - Setting Storage Tank Pressure
    By Budster in forum Pumps and Tanks Well Forum & Blog
    Last Post: 09-05-2005, 09:23 AM
