You do dislike copper, it is obvious, I'm going to johnwhipple you from now on.
Hahaha, bring it on
Seriously, I don't "dislike" copper. I think it is/was a fine system. The main reason I push so hard the benefits of PEX is that I think there are a lot of rumors and false ideas out there about it, perpetuated by old school plumbers who are either afraid of PEX, just don't want to change, etc. I do prefer PEX, and wouldn't be likely to choose copper in many circumstances, though there are some (my radiant floor heating system is all copper between the tank/pumps/etc. The circuits and each floor's manifolds are PEX. I use copper manifolds for my PEX, not those plastic things. I just don't like whole house copper systems as much these days, after having a home run PEX system, I'll never go back.
To be fair, a couple of pitfalls of PEX...
It is less resistant to a glancing blow from a nail head or screw. Copper "might" survive a glancing hit, PEX probably won't. If it is very loose, it might move out of the way enough to be saved, but generally it is more susceptible to this type of damage. Direct hits will puncture both copper and PEX equally.
Apparently mice sometimes will chew through it, though I've heard very few actual accounts of this, just rumors. Copper isn't really attractive to our rodent friends as an entry point to the home.
It looks "cheaper," if you care about the appearance of quality over the experience of quality.
It hasn't been proven as many years as copper (a bit over 40 years of continuous use has shown no real problems, other than some initial issues with some of the fittings that has been resolved since).
The fittings can cause reductions in flow rate, especially if you use a lot of them for some strange reason (but so do copper fittings, in different ways)
The pro tools are expensive.
Its worthless if you're a scrapper trying to steal someone's plumbing... oh wait, thats a good thing.
