Results 1 to 7 of 7
Thread: Cement Lined Water heater?
    DIY Junior Member TMP>9a59's Avatar
    Dec 2011
    Florida
    Default Cement Lined Water heater?
    Just starting the research phase of a new water heater for the house. I see there is a company named Hubbell that makes a cement lined water heater instead of glass lined. Their Model E is a light commercial duty, so for a home it would be more than adequate (if sized correctly). I know it would be heavier, but the location is on a concrete slab with good access.
    Other than costing more, is there any real differences (advantages) to a so called "stone lined" water heater? Does it interact with softened water in a detrimental way?
    I have found a few conversations where these types of heaters have a life span of 20 plus years.
    Feb 2011
    NW Ontario, Canada
    What would be the heat source? Sure, the tank could last longer but it could fill up with lime scale and affect the heat transfer. I know that I would not want a gas water heater to last 20 plus years as the efficiency would be way off with no easy way to clean it.
    Dec 2009
    northfork, california
    I have only seen cement lined electric heaters, as they are spun coated, not possible with a central tube.
    I was cutting a 30 year old one up for a trough, when I learned of their existence - couldnt quite figure why it was so heavy. No torch can cut a cement lined tank. Scrapped it, and made a bunch because they dont look inside.
    I would go with it, but you need good access to move it.
    Aug 2009
    South*East
    Years ago tanks that were used to store hot water that was produced from various sources were stone lined. Many were 80 and 120 gal. I can still see them sitting horizontally on pipe stands 2'-3' off the floor. I'm sure hj also remembers them. They also were covered with asbestos.
    John
    Dec 2009
    This one had a georgeous copper finned heat exchanger in a set of ports which I did manage to cut out. No Asbestos. Likely a solar tank.
    Feb 2011
    NW Ontario, Canada
    Quote Originally Posted by ballvalve View Post
    I have only seen cement lined electric heaters, as they are spun coated, not possible with a central tube..
    When I did a quick google search I was finding steam heated units but have since found the electric model E the OP mentioned.
    http://www.hubbellheaters.com/html/modele.htm
    Dec 2009
    I had another one that I welded a patch on over a leak in my poor youth, and the damn thing lasted another 15 years. "curbside pickup" built my first house.
    What I fancy is building a house with those huge bales of compressed cardboard boxes. Probably win every enviro award in the nation.
  1. Replacing indirect water heater with gas fired heater?
    By MHM in forum Water Heater Forum, Tanks
    Last Post: 08-29-2011, 12:15 PM
  2. question on water heater venting (orphaned water heater)
    By harveymasons in forum Plumbing Forum, Professional & DIY Advice, Tips & Tricks
    Last Post: 08-23-2010, 06:11 AM
  3. need for lined toilet tank?
    By Kathryn Hamer in forum Toilet Forum discussions
    Last Post: 05-05-2009, 12:39 PM
  4. Toto Drake LINED TANK?
    By sulfur in forum Toilet Forum discussions
    Last Post: 04-01-2007, 02:47 PM
  5. Hot water heater vs. Indirect water heater
    By jmillican in forum Shower & bathtub Forum & Blog
    Last Post: 04-26-2006, 10:10 AM
