Results 1 to 4 of 4
Thread: Sidewall Vent below modcon boiler?
    DIY Member Buffalobillpatrick's Avatar
    Sep 2011
    Stonewall Colorado
    Default Sidewall Vent below modcon boiler?
    Is a sidewall vent allowed to exit house 7' below where it exits top of power vented TT Solo boiler?
    Is that boiler a closed combustion device, i.e., have an air intake as well? If so, you probably don't want it there. The instruction manual will have the appropriate restrictions. Since a vent may not seal perfectly, even though it is an exit, there are restrictions on potential co intake.
    Modcons don't like intake air with stuff like potentially chlorine, lint, or other chemicals in it, either. Those could be coming out of the vent. Again, your best thing is the installation manual and potentially, the local inspector's office, but they usually go by the restrictions in the installation manual.
    Sep 2011
    Stonewall Colorado
    Yes, closed combustion.
    I have read the TT Venting Supplement closely & see nothing saying this is wrong.
    All of the guides I've read, show diagrams of the minimum clearances required to things like overhangs, windows, doors, walkways, and other vents. If you are adhering to those, then you should not have problems. When I had my mod-con installed, where it was the easiest to run the vent lines would have been within a few feet of two dryer vents and another heater's exhaust, so I had to run it out the opposite wall of the house. Still within the limits of length, but much more of a pain.
  1. Modcon with IHW Tweaking
    By chris24 in forum Boiler Forum
    Last Post: 12-01-2012, 09:28 PM
  2. Modcon buffer tank temperature
    By Buffalobillpatrick in forum Boiler Forum
    Last Post: 01-08-2012, 09:54 AM
  3. 3x Oversized ModCon with Concrete Slab, New Home
    Last Post: 09-27-2011, 08:06 PM
  4. modcon or not ?
    By dukehayduk in forum Boiler Forum
    Last Post: 12-23-2010, 10:45 AM
  5. Tie sink vent & boiler vent together?
    By zaothusia in forum Plumbing Forum, Professional & DIY Advice, Tips & Tricks
    Last Post: 01-06-2010, 02:39 PM
