Mineral wool sounds like a requirement for steam or other high temp.
The foam type is actually quite good. Just make sure that you seal the seam completely with contact cement. When doubling up, grab a piece of foam insulation for your pipe size and find a piece to fit around it. It would be better to be a little too big than too small and leave a gap. Some here might tell you I'm stupid for suggesting the double insulation. I might be if it were an inch or so thick to begin with, but it's 3/8-3/4 inch.
Home depot has 3/8", Grainger has 3/4". McMaster up to 2"
1/2" pipe (5/8" OD) + 3/8" insulation = 1-3/8" OD
1-1/4" pipe has an OD of 1-3/8", so insulation for 1/2" and 1-1/4" @ 3/4"
will allow thickness = 1-1/8".
3/4" pipe (7/8" OD) + 3/4" insulation = 2-1/8" OD
2" pipe has an OD of 2-1/8", so insulation for 3/4" and 1-1/2" @ 3/4"
will allow thickness = 1-1/2". 2" pipe insulation also comes in 1" wall thickness. Overkill, perhaps.
Water heater mfgs claim < 1/2 deg/hr loss and their tanks have 2" of rigid foam insulation.
Anyway...
Grundfos has a recirculation pump that mounts at the water heater and uses a special valce under the sink/ at the shower to manage the recirculation. You wouldn't need an outlet under the sink.
See this link.
http://www.grundfos.com/web/HomeUs.n...ag/PAVA-56TMVA
