Results 1 to 4 of 4
Thread: No cold water in bathtub faucet
    DIY Junior Member ARV's Avatar
    Dec 2011
    Lovington, Arkansas
    Unhappy No cold water in bathtub faucet
    Bathtub cold water suddenly quit. Hot water faucet still fine. Removed and examined cartridge. All OK. I also had wife stand by as I did a quick turn on and off at the home shut off valve. No water pressure! All other cold water faucets work. There must be somthing plugging the bathtub cold water line. What is best approach to clean out? This is my mother-in-law's home and quite old plumbing.
    Could be anything, but if this is a three handle (hot/cold/diverter) setup, it could be as simple as changing the washer. When changing the washer, sometimes you need to change the stem, and may want to replace the valve seat, but is might just need a washer.
    Feb 2011
    NW Ontario, Canada
    I presume the entire stem/washer/seat/cartridge was out when you had the wife on standby with your test. I don't know where Lovington is and whether a frozen water line is within the realm of possibility.
    [edtit]OK, since the OP updated his profile, it is not likely to be a frozen line.
    A stuck balancing spool in a Moen "MoenTrol" or Delta "ScaldGuard", (or Danza, Pegasus, etc), could act that way since it does NOT come out with the cartridge.
  1. warm water from the cold faucet?
    By bigelee in forum Plumbing Forum, Professional & DIY Advice, Tips & Tricks
    Last Post: 07-14-2009, 01:42 AM
  2. Tub Faucet, Cold Water Slow
    By molo in forum Plumbing Forum, Professional & DIY Advice, Tips & Tricks
    Last Post: 06-09-2007, 06:52 AM
  3. Fixing a cold water leak from bathtub spout
    By RUNEMASTER in forum Shower & bathtub Forum & Blog
    Last Post: 03-15-2006, 09:03 AM
  4. Looking for an attractive cold water only bar faucet
    By dhoerl in forum Plumbing Forum, Professional & DIY Advice, Tips & Tricks
    Last Post: 12-28-2005, 03:04 PM
  5. Cold Water in Bathtub
    By John456 in forum Shower & bathtub Forum & Blog
    Last Post: 01-04-2005, 09:49 AM
