Results 1 to 9 of 9
Thread: water spraying up through drain by washing machine when shower is on
    DIY Junior Member vandjmp's Avatar
    Dec 2011
    Toronto, ON
    Default water spraying up through drain by washing machine when shower is on
    I just moved into a stacked condo that was built in 2004. The washing machine is upstairs on the second floor near the full bathroom.
    I first noticed that there was water on the ground in the washing machine room. I assumed it was coming from the washing machine, and that maybe the pipes needed to be cleaned out or washers replaced to make the seal tighter on the pipes (this has not been done).
    But then I noticed that when the shower in the bathroom is on, water splashes up from the drain in the washing machine room. The toilet does not always flush fully and the sink drains water very slowly. What could it be? Is it a clogged pipe? Are these things all connected or separate issues? Could a clogged pipe effect the washing machine's ability to drain without leaving a leaky mess on the floor?
    Please help!
    Oct 2011
    When you say water splashes up from the drain in the washing machine room, is this drain a floor drain or is it a standpipe.
    Nov 2010
    Maine
    You have either a drain obstruction or someone piped the whole thing wrong.
    You say that the shower AND the washer are both on the second floor, therefore, unless you have managed to change the rules of physics, water flowing into a shower drain at the floor level CANNOT overflow, much less spray, out of the washer drain three and half feet above the floor. Either you have misdiagnosed the problem or have misstated it to us. It takes a VERY unusual stoppage to create ANY problem on the second floor plumbing.
    Dec 2011
    Toronto, ON
    The drain that has water spraying up from it is a floor drain. This floor drain is right beside the washing machine. It is about 10 feet from the shower. Both are on the second floor. Maybe it is not a blockage at all, maybe it is loose washers on the pipes leading to the washing machine? The spraying is more like water splashing up from the drain. It is not a huge amount, but enough to get the floor and baseboards wet around the washing machine.
    I also see that from the previous owner there had been a problem: down on the first floor they had to remove wet dry wall, but don't know what that previous problem was about.
    HOW they installed the piping for the floor drain would determine whether it is because of a drain problem, which can be fixed, OR because of a poor installation which MIGHT NOT be fixable.
    In the Trades mtcummins's Avatar
    Jun 2010
    Pittsburgh PA
    If you have a snake (or can borrow/rent one), you might as well try snaking the line through the floor drain, but I doubt that's the problem from your description.
    This doesn't sound like something that can be diagnosed online. You probably need to call a local plumber to come take a look at it.
    Oct 2011
    Quote Originally Posted by vandjmp View Post
    The drain that has water spraying up from it is a floor drain. This floor drain is right beside the washing machine. Maybe it is not a blockage at all, maybe it is loose washers on the pipes leading to the washing machine? The spraying is more like water splashing up from the drain. It is not a huge amount, but enough to get the floor and baseboards wet around the washing machine.
    Since it's a floor drain, take a bucket of water and pour it in and report your findings.
    Also what "loose washers" are you talking about on the pipes leading to the washing machine? It would seem if your "pipes" as you call them or supply lines are leaking that would be a constant leak.
    Do you mean the flexible hoses from the shutoff valves to the washing machine like the photos below?
    Can you post a few photos of your setup?
    DIY scratch-pad engineer leejosepho's Avatar
    Nov 2006
    I wonder whether the trap for the floor drain might be serving as a running trap for the shower coming in from the side and then that lateral flow splashes up when it hits the far wall.
    "Great minds discuss ideas, average minds discuss events and small minds discuss people." --Eleanor Roosevelt
  1. Washing machine drain tie in
    By phatman1969 in forum Plumbing Forum, Professional & DIY Advice, Tips & Tricks
    Last Post: 01-17-2011, 03:03 PM
  2. Design, connecting shower and washing machine drain to the same sewer pipe.
    By Florin in forum Shower & bathtub Forum & Blog
    Last Post: 10-18-2010, 08:54 PM
  3. Soap suds coming out from drain pipe for my washing machine no problem with water
    By krish in forum Plumbing Forum, Professional & DIY Advice, Tips & Tricks
    Last Post: 08-21-2010, 12:30 PM
  4. Washing Machine Drain
    By sbiggs65 in forum Plumbing Forum, Professional & DIY Advice, Tips & Tricks
    Last Post: 01-15-2010, 11:22 AM
  5. Washing Machine Drain
    By MrBrown in forum Plumbing Forum, Professional & DIY Advice, Tips & Tricks
    Last Post: 07-26-2009, 06:23 PM
