Results 1 to 5 of 5
Thread: Silicone or plumbers putty?
    DIY Junior Member joeriley2005's Avatar
    Nov 2011
    Bothell, WA
    Default Silicone or plumbers putty?
    I'm installing my new drain kit to my new shower pan and the instructions say to put silicone between the drain and the pan. I've always used plumbers putty but I should I use silicone in this case since the instructions call it out?
    What do the plumbers prefer?
    thanks
    I've been using Silicone.
    Putty can dry out over time, and then the drain will be loose.
    For that application, I use silicone, but be sure NOT to get it on the strainer's threads, because it could keep it from tightening properly. Plumber's putty often begins to leak and usually it is difficult to get to the nut to loosen it and reset the drain.
    DIY Member Belmondo's Avatar
    Dec 2011
    New Jersey
    So where do you guys still use putty? I've used it for seating stainless drop in sinks, as per directions, but I think I saw a plumber on a home improvement show use silicone there too. What about the basket on that sink?
    atound the sink, I use "tub and tile sealant", NOT putty or silicone. The basket strainers, depending on the brand, I use plumber's putty, although some do NOT require anything other than the rubber seal.
  1. When to silicone (or putty) faucets
    By DavidTu in forum Plumbing Forum, Professional & DIY Advice, Tips & Tricks
    Last Post: 10-01-2011, 09:08 PM
  2. ABS to CI Hub with plumbers putty
    By lloyda in forum Plumbing Forum, Professional & DIY Advice, Tips & Tricks
    Last Post: 11-07-2009, 01:03 PM
  3. Putty or Silicone?
    By USAFRet in forum Shower & bathtub Forum & Blog
    Last Post: 10-19-2009, 11:24 AM
  4. Silicone or Putty??
    By Waltman in forum Shower & bathtub Forum & Blog
    Last Post: 02-08-2009, 08:06 AM
  5. plumbers putty
    By rbig in forum Plumbing Forum, Professional & DIY Advice, Tips & Tricks
    Last Post: 07-03-2008, 06:04 AM
