Results 1 to 8 of 8
Thread: Need help.. Light fixture with two ground wires???
    DIY Junior Member kali2024's Avatar
    Mar 2011
    NJ
    Default Need help.. Light fixture with two ground wires???
    Hi all, so I've got a light fixture with a black, a white and what looks like two ground wires.. what do i do with these? The house box/outlet has a black, white and ground. Thanks in advance.Name:  photo.jpg
Size:  57.6 KBName:  photo copy.jpg
    Mar 2011
    NJ
    I meant to say that I've never seen two copper wires in a fixture before.. do I tie them together to the end of the ground from the house and put that cap thingie on? (house ground is attached to ground screw but has about two inches hanging)
    Tie both of the ground leads into the ground from the power cable.
    Mar 2011
    NJ
    Thank you!!! Just out of curiosity... why was the fixtures supplied with two copper wires? What's the point? Wouldn't one be enough?
    DIY Member ImOld's Avatar
    Jun 2013
    In the rumble seat
    Quote Originally Posted by kali2024 View Post
    It has to do with making all metal or conducting parts the same electrical potential to avoid shocks.
    It's called "bonding".
    When you manufacture a piece of electrical equipment, even though the parts look to be attached to each other securely, electrically they may be insulated by paint or poor assembly.
    The fixture has a UL label which means it has been tested with the two wires as a requirement.
    Mar 2011
    NJ
    Makes sense.Thank you for taking your time to answer.
    If for some reason, the nut came loose, allowing parts to separate, they wouldn't all be grounded. Can't see what's inside, but there may be a similar situation.
    Smile wire
    The second ground wire may be connected to the socket, which could be housed in plastic and thus isolated from the housing.
  1. Multiple White and Ground Wires in Bus Bar.
    By molo in forum Electrical Forum discussion & Blog
    Last Post: 03-11-2010, 05:02 AM
  2. Crimping ground wires in an outlet box
    By dorothy in forum Electrical Forum discussion & Blog
    Last Post: 01-26-2010, 05:20 AM
  3. DIY - Split receptacle to light switch and light fixture with 14/2?
    By AJM in forum Electrical Forum discussion & Blog
    Last Post: 11-24-2009, 04:36 PM
  4. Ground wires after installing pex
    By Rocknroj in forum Plumbing Forum, Professional & DIY Advice, Tips & Tricks
    Last Post: 05-07-2009, 07:40 AM
  5. Ground Wires Only Twisted
    By kraftwerk in forum Electrical Forum discussion & Blog
    Last Post: 01-05-2009, 04:19 AM
