Results 1 to 5 of 5
Thread: Pilot light is lit and stays lit but will not flame up to heat water
    DIY Junior Member tamaram's Avatar
    Dec 2011
    Seattle
    Default Pilot light is lit and stays lit but will not flame up to heat water
    I just installed a new Bradford 40 gallon water heater model M-I-403S6FBN and the pilot light ignited just fine but when I turn up the dial to "Hot" or "A" "B" or "C" tetmperature settings- it will not increase the flame to heat water. The pilot light is actually a bigger flame then the flame I get when I turn it up. In other words the flame size decreases when I turn the dial from Pilot to a heat setting. I used the same water connections as my old one and the lines are the same - tank filled just fine, the gas line is the same also. The only thing I replaced is the gas connection line as the old one was crimped. What could be causing this? The pilot stays lit but the burner will not fire up?
    DIY Junior Member tray's Avatar
    Dec 2011
    west henrietta, ny
    did you remember to turn gas valve from pilot to on otherwise no gas feed to burners
    Dec 2011
    Seattle
    Quote Originally Posted by tray View Post
    Yes - but when I turn it to a temp or on setting the pilot flame actually gets smaller.
    Dec 2011
    west henrietta, ny
    Sounds like you need a manometer to messure gas pressure. If you look closely on the gas valve there two ports with an allen wrench stud keeping them closed. one for inlet pressure and the other outlet pressure.inlet pressure could be between7-13in/wc and outlet on most water heater gas valves is 4in/wc. you probably will need to call service tech with the proper equip
    In the path of the flame of the pilot light, there's usually a probe. If that probe isn't getting hot, it will not light the main burner. It may be bent and all you need to do is bend it so that it is in the pilot's flame envelope.
  1. Rheem Powervent 2 pilot flame question.
    By lerdmann in forum Water Heater Forum, Tanks
    Last Post: 05-29-2010, 05:44 PM
  2. No flame to heat water
    By Phabej in forum Water Heater Forum, Tanks
    Last Post: 10-18-2009, 02:46 PM
  3. water heater pilot light problems
    By scorch in forum Plumbing Forum, Professional & DIY Advice, Tips & Tricks
    Last Post: 12-17-2008, 03:59 AM
  4. Water heater pilot light goes out
    By Coldnwet in forum Plumbing Forum, Professional & DIY Advice, Tips & Tricks
    Last Post: 11-09-2008, 01:45 PM
  5. Pilot won't light on Reliance 501 Water Heater
    By HarmonyRose in forum Plumbing Forum, Professional & DIY Advice, Tips & Tricks
    Last Post: 02-27-2005, 03:22 PM
