Results 1 to 7 of 7
Thread: Price Pfister shower diverter
    DIY Junior Member wstaubin's Avatar
    Dec 2011
    Md
    Default Price Pfister shower diverter
    I've got a couple year old single handle Pfister shower diverter (Parisa or similar). It looks to be installed upside down. When you divert the water to the tub spout you still get some water coming out the shower head. Is there anything to do other than reinstalling right side up?
    Thanks for thoughts.
    It is NOT installed upside down, if it were you would have a LOT of water coming out of the shower, but it probably DOES have PEX tubing from the valve to the spout. That can only be fixed by opening the wall and installing a copper drop pipe.
    Dec 2011
    Md
    On the valve body the outlet that says tub is on top and connected to the shower pipe. Perhaps there's not a Lot of water coming out the shower head because water pressure is not great. Thanks
    It is possible to correct it without inverting the valve, but it might be more costly than rotating the valve. IF there is enough tubing beteen the valve and the closest fitting for all four pipes, making "symetrical" cuts will allow you to rotate the valve and reconnect it using "slip" solder couplings, making it a fairly simple job.
    Hi wstaubin,
    Sorry you're having a problem. If you think we could help, our Consumer Service Team is available to assist. All we need is some additional information.
    Please provide:
    * The model number of the product. If you do not know this, please follow these directions: http://www.pfisterfaucets.com/do_it_...lf/how_to.aspx
    * Any other specifics on the issue you’re experiencing
    * A method to contact you (ex. email, phone, etc.)
    * Best time for contact (ex. mornings, evenings, etc.)
    Please send this information to us at pfistersocial@bdhhi.com.
    We apologize for your inconvenience and look forward to resolving this matter as soon as possible.
    Sincerely,
    The Pfister Team
    Pfister is a part of the Stanley Black & Decker Hardware and Home Improvement (BDHHI) Group.
    Plumber jimbo's Avatar
    If you get a good normal flow from the spout when you select that, then I would not immediately suspect that the valve is upside down.
    > if plastic tubing was used for the connection down to the spout, that is a problem.
    > get a small gauge, and check the pressure in your house. If it is quite high, that will also cause a problem that would not otherwise exist in a properly installed valve,
    Dec 2011
    Md
    I did verify that the valve is installed upside down (outlet marked "tub" is on top and connected to shower pipe). The water pressure is low so not that much water comes out of the shower head when the tub spout is running. I was hoping there was some easy thing to do other than reinstall valve.
  1. Key step to fix the Price Pfister bath diverter stem
    By Mechanical Engineer Engke in forum Shower & bathtub Forum & Blog
    Last Post: 12-28-2011, 06:50 AM
  2. Price Pfister Diverter problem
    By FrancisKuo in forum Shower & bathtub Forum & Blog
    Last Post: 12-27-2011, 10:39 AM
  3. Key Step to fix TWO Price Pfister Bathtub Diverter Stems - Update 12-05-11
    Last Post: 12-09-2011, 07:01 AM
  4. Price Pfister Kitchen Diverter Tee
    By pmizell in forum Plumbing Forum, Professional & DIY Advice, Tips & Tricks
    Last Post: 12-13-2009, 05:20 PM
  5. Price Pfister Shower Diverter Removel
    By Adam S in forum Shower & bathtub Forum & Blog
    Last Post: 11-11-2004, 04:48 AM
